fuel smell while driving?
Old Jul 17, 2005 | 08:28 PM
tigmaned's Avatar
tigmaned
Default fuel smell while driving?
been smell gas while i am driving my 86 vette? i thought i was coming form the tanks some were, took the rubber boot off to investagate. trimmed a bad hose end ans reclamped. but i still smell gas while driving a while? am not resure but it seems worst when i am slowing down, return line?? i don't see any real clean aras giving up the location? any one else have this, was wondering what they did?
thanks!
Old Jul 17, 2005 | 08:54 PM
ittlfly's Avatar
ittlfly
If your not showing an obvious gas leak, then it's probably your emission evap system....canister, solenoid, or purge tank valve.
Old Jul 18, 2005 | 02:13 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Did you install new o-rings on the bolts that hold the fuel and pump inplace?
Old Jul 18, 2005 | 02:58 AM
rodj's Avatar
rodj
As above , disconect the line from the charcoal canister and see if you can blow through it.Had same prob , steel pipe where it makes
90 degree turn at wheel arch was full of rust flakes. Cleaned out . no more fumes
Old Jul 18, 2005 | 05:35 AM
conv90's Avatar
conv90
Usually the canister in the front driver corner under the hood.
Try to check the leak because the gas is very dangerous under the hood.
-Beppe-
Old Jul 18, 2005 | 08:32 PM
Mike263's Avatar
Mike263
Good question.
Had the same problem on my 86 earlier this year. It, indeed, turned out to be o-rings on the bolts.
You might check the line that tuns from your evap canistor to the tank. Most of the tubing is steel, but in a couple of places it's rubber (prone to rotting out). A common leak is just in front of the left rear wheel - about 2 inches of line is rubber there.
To fuel smell while driving?
