Voltage/alternator question...
Old Jul 17, 2005 | 11:53 PM
kingcobra's Avatar
kingcobra
Default Voltage/alternator question...
I have never had a problem with the voltage on the vette until today. I installed a Pioneer Head unit. ( cd player ) and the dash lights are very dim.. my light **** is turned all the way up too. while im driving, the lights brighten up but only for like 2 seconds, and its only every once and a while. It also does it even if the CD player is off. I was wondering what the problem could be. What is the Amperage output on the stock alternator? Thanks guys ! hopefulyl I can get some help.
Old Jul 18, 2005 | 12:01 AM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
I believe it's 105 amps. See my post. It must be the day for Voltage problems.
Old Jul 18, 2005 | 12:33 AM
SunCr's Avatar
SunCr
Hard to think it's a system voltage problem unless you've installed some sort of mega amp. Depending on year and whether or not it has electronic air and whether or not it's replaced a Bose, the radio dim signal is from the a/c panel and I believe some have had problems once that connection is eliminated or left open. Might try the Radio Section, but post the Year and what type of radio you've replaced.
To Voltage/alternator question...
