No Brakes!!
Old Jul 18, 2005 | 09:26 AM
pair o jacks's Avatar
pair o jacks
From: 89 Coupe L98 Auto 54k Dk Red Med Oak Forest, Illinois
Default No Brakes!!
Heres the story....driving on Sat. everything OK, then the brake pedal got soft, then it went all the way to the floorboard, car barley stopped and the "Brake" light goes on when the pedal goes to the floor. No brake fluid leaking from anywhere....where do I start to get this problem fixed????
Old Jul 18, 2005 | 10:35 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Simplest and cheapest, bleed the entire system. You'll be able to get a good close look at all of the calipers and as you go around one by one, if there's a leak, you'll find it fast.
Old Jul 18, 2005 | 10:37 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If there is fluid in both resevoirs I would strongly suspect the MC.
Last fall I installed a rebuilt MC into my '88; it cost $45 from the local AC Delco dealer.
Old Jul 18, 2005 | 10:47 AM
runner140*'s Avatar
runner140*
First guess would be master cylinder. Usually when you get a soft pedal and no brakes we think M/C. Hard pedal we think brake booster.
With a new M/C you should be in good shape. Might be a good time to do a complete flush and bleed.
Old Jul 18, 2005 | 11:22 AM
rws.1's Avatar
rws.1
Boiled fluid can incorporate air which can give rise to spongey feel.
Pedal to the floor is usually low or no fluid or a bad master cylinder
Old Jul 18, 2005 | 12:45 PM
Johns94's Avatar
Johns94
CF Senior Member
St. Jude Donor '05
Looks like you got some good advice Jack. If there is anything I can do, give me a call.
Old Jul 18, 2005 | 02:48 PM
pair o jacks
Ok, thanks everybody...I'm gonna try and relace the MC first and do a complete bleed/fluid change
Old Jul 28, 2005 | 01:33 PM
pair o jacks
Put in the new master cylinder yesterday, installed speed bleeders and did a complete fluid change/bleed.....good as new. Thanks to everyone for their help!!
To No Brakes!!
