Window Wipers
Old Jul 18, 2005 | 09:54 PM
thornton310's Avatar
thornton310
Default Window Wipers
I recently changed the wiper switch on my 85 C4. I did this because when I turn the wipers on, they stay on. This did not work, they still stay on. Any ideas? Thanks.
Old Jul 18, 2005 | 11:12 PM
Ramanstud's Avatar
Ramanstud
what do you mean "they stay on." you have to turn off the ignition to get them to stop, or...?
generally speaking, if it isn't the wiper switch in the doorpanel, it will be the black plastic wiper cover (near the rear of the driver's side valve cover in the engine compartment). Look to see if the cover is cracked, damaged or loose. Also, inspect the wiring harness to make sure everything is plugged in and not damaged.
Try to give us some more details of what the wipers are doing.
Old Jul 19, 2005 | 01:49 AM
thornton310
Exactly, the wipers stay on and I have to turn the car off in order for them to stop. I will look at what you suggested, any other ideas?
Old Jul 19, 2005 | 02:58 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I'll bet good money the lower portion of your wiper motor is cracked off and moisture is getting in. If not the complete cause it is part of the problem for sure.
Old Jul 19, 2005 | 06:31 AM
cajun86's Avatar
cajun86
Its the park switch in the wiper motor. Same thing happened to me just go by your GM dealer and get a wiper park switch.
To Window Wipers
