Ground strap location??
Old Jul 19, 2005 | 11:39 PM
jimkari's Avatar
jimkari
Default Ground strap location??
While taking off my bell housing on a 93 six speed, I accidently pulled the uninsulated ground strap off the car. I know one end mounts to the driver's side bell housing stud. I have no idea where the other end mounts. Unfortunately my manual simply states to remove the ground strap. It does not provide the location. Does anyone know where it mounts? I'm assuming it's on the firewall. I just don't know where.
Thanks for any help you can provide.
Jim
Old Jul 19, 2005 | 11:55 PM
500hp's Avatar
500hp
I believe it bolts to the TOP of the frame, slightly forward from where it bolts to the tranny. I'm sure it's a fun spot to try to get at with the engine still in the car. Maybe try to sneak down around the brake booster with a long, ball-end extension. Good luck.
Old Jul 20, 2005 | 01:59 AM
Mo_Bandy's Avatar
Mo_Bandy
It goes to the frame....
Mo
Old Jul 20, 2005 | 07:24 AM
jimkari's Avatar
jimkari
Thanks guys, I'll give it a try!!
Jim
Old Jul 20, 2005 | 07:33 AM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
When I was under mine replacing the slave cylinder I noticed mine was broken off. It, if memory serves, was bolted just above that location to the lower part of the frame.
To Ground strap location??
