Copper Plug wires
Old Jul 20, 2005 | 01:30 PM
FD2BLK's Avatar
FD2BLK
Default Copper Plug wires
Anyone using copper plug wires? I am thinking of getting a set of copper wires made to work with my Delteq ignition system. I talked with elite spark about a set of custom made wires and he mentioned he has copper wires using 10mm Insulation. I am a bit concerned I wil pick up some EMI problems with the radio and possibly the knock sensors but was curious if anyone was running copper and if so any problems? THe other option is a set of either 8.5mm or 9mm wires.
Old Jul 20, 2005 | 03:28 PM
Lone Ranger's Avatar
Lone Ranger
I think most after market wires use a nickel alloy or stainless steel for the conductor. Copper will cause too much RFI/EMI, even if spiral wound as is the standard method.
Old Jul 20, 2005 | 05:35 PM
pwrful c4's Avatar
pwrful c4
I am useing Elite Spark plugs custom made wires on my Delteq with no problems.
Old Jul 20, 2005 | 08:43 PM
FD2BLK's Avatar
FD2BLK
what wires are you using? The 8mm's 8.5's, 9's or the 10mm Copper cores?
To Copper Plug wires
