cleaning TB and IAC
Old Jul 20, 2005 | 05:21 PM
Bilyk's Avatar
Bilyk
Default cleaning TB and IAC
Is there another tutorial somewhere that I should see other than what we have in the tech center? I need pics.
Old Jul 20, 2005 | 05:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you have an L98 it's pretty easy and a good time to do the TB coolant bypass mod.
Actually you can clean the TB bore and throttle plates with it installed onto the plenum. Be sure to use only TB cleaner though.
To clean the IAC just remove the connector and unscrew it from under the TB. Then use TB cleaner on cotton swabs to clean out the IAC bore; check with a mirror to verify no cotton strands got caught inside.
Old Jul 20, 2005 | 10:20 PM
Bilyk's Avatar
Bilyk
thanks for the tip
i was about to remove everything
To cleaning TB and IAC
