temp sensor on the block
Old Jul 21, 2005 | 09:25 AM
conv90's Avatar
conv90
Default temp sensor on the block
yesterday I was checking if the TB bypass was leaking and I noticed that the sensor on the front of the engine (just under the intake manifold) has the electrical connector a bit loose
I unplgged it and now I can see the two blades of the sensor...
I plugged in again but i noticed that the stock plastic wing that secure the connector to the sensor has NO a place to hook on the sensor. So it can be put on but not secured.
someone has a close pic of this sensor? Maybe I hve the wrong one installed?
There is also a sensor in the pas side heads . Is this also a water temp sensor? Why two? Which is the difference?
-Thanks-
Old Jul 21, 2005 | 10:15 AM
Aardwolf's Avatar
Aardwolf
Is there a piece of plastic broken off? Perhaps a spot of glue would hold the connector on. This car is a 90? On my car there is also the cold start temp. sensor there. They have different pig tails.
Old Jul 21, 2005 | 10:38 AM
CFI-EFI's Avatar
CFI-EFI
-Thanks-
The sensor in the front of the intake manifold is water temperature sensor for the ECM. The sensor in the right head is for the dash gauge. If there is similar device in the left head, it is the aux fan switch, but the aux fan may be ECM controlled, and that hole plugged, in 1990.
RACE ON!!!
conv90's Avatar
conv90
Yes, it's a 90 and I noticed than when hot the connector is more hard to unplug. (probably the heat expand the metal)
-Beppe-
Old Jul 21, 2005 | 11:48 AM
SunCr's Avatar
SunCr
It's the Coolant Temp Sensor and since it's used for everything GM builds, doubt you have the wrong one. I'd replace it as the tang has broken off and if the harness falls off, the ECM is going to think it's -32 degrees and generate a Code 15. That won't strand you (the engine will run on backup) but with the throttlebody off, swap it out while it's easy to get to. Can't recommend gluing it - if it goes bad, you will also be splicing in a new harness and since the signal it sends depends on resistance - potentially adding another source of resistance to the circuit is never wise.
Old Jul 21, 2005 | 12:37 PM
conv90's Avatar
conv90
Ok, I understand the problem...
the sensor should be like this:
and the connector like this:
my sensor has NOT the black plastic thing attached to..
-Beppe-
To temp sensor on the block
