Wierd Dash problem
Old Jul 21, 2005 | 02:02 PM
kingcobra's Avatar
kingcobra
Default Wierd Dash problem
Ive owned the vette for about a month now and ive noticed the digital dashboard dims out and comes back to life. These are the things ive noticed latley, The dash seems to dim only at night. When the dashboard dims, the voltage light is always below 11.6 volts and the warning light comes on. When I step on it the voltage builds and once it its above 11.7 volts the dash goes dim. This doesnt make sense to me, wouldnt it be theother way around? dash dims when the voltage is low? The car has aftermaket ignition and the previous owner said the low voltage light would come on if he had the AC on.. but this doesnt seem to make a difference if the AC is on or off... or the headlights for that matter. Hopefully you guys can help me out ~Jason
Old Jul 21, 2005 | 10:58 PM
vettenut85's Avatar
vettenut85
could be your alt is not putting out what it should.with the engine running the volts should read about 13.8-14.3...could also have a ground problem.
Old Jul 22, 2005 | 10:03 AM
rick lambert's Avatar
rick lambert
and you might want to check the connection to the alternator.
Old Jul 22, 2005 | 10:31 AM
tigmaned's Avatar
tigmaned
only 11.6 volts?? kind of low, my 87 is at 13.8 well when i am watching it?? but the digtial dash are suppose to dim some at night so as to not distrub driving with a brite dash in the dark, but your problem is some thing else like the other guys have said??
Old Jul 22, 2005 | 10:37 AM
C10 JDR's Avatar
C10 JDR
Time for a new alternator. Check alt and battery connections first though.
To Wierd Dash problem
