1994 ABS troublecode help
Old Jul 21, 2005 | 05:46 PM
mswasty's Avatar
mswasty
Cruising
Default 1994 ABS troublecode help
Hello fellow Vette Gurus,
Can someone do me a huge favor and look up an ABS code for me from their 92-96 factory service manual. It's ABS Code 65 "Adjuster Assembly Circuit Malfunction". I can't find anything about this code on the web. What the heck is the Adjuster Assembly???
Thanks a ton
Matt
Old Jul 28, 2005 | 05:06 PM
Red Dwarf's Avatar
Red Dwarf
ABS 65
The adjuster assembly circuit provides both power & ground to the adjuster assembly to help control engine torque during a TCS event.
The DTC will set when : If CKT 560 or Ckt 561 are shorted to ground, shorted to voltage, shorted to each other. or both open at the same time.
Manual advises that a thorough inspection of the wiring & connectors be performed before replacing parts.
