I Have Many Mods And All I Have To Break Down Pollution Is The Cat. And Only The Cat. The Car Smells Like Its Running Rich And I Have An Adjustable Fuel Pressure Regulator. I Also Have A Custom Chip.
Is This Just A Matter Of Dialing Down The Fuel Pressure And Replacing The Stock Chip? Any Suggestions?
How Many Psi Should I Be Running? With 24 Lb Injectors, Ram Air, 52mm Tb, Large Tube Runners, Bigmouth Manifold, Fully Gutted Plenum And Maf Sensor, Headers Etc.
Any Help Would Be Appreciated.
John
I failed UT. I/M test twice,on the third try I set timeing at about 5 or 6 degrees above tdc,which is about 10 or 11 degrees retarded.Then I advanced the tps sensor to max,about 61.This really leaned out the air-fuel mix.Also I cut fuel pressure back to about 38 psi.I changed the chip to a hypertech that came with the car,with these changes I passed I/M test.
I have a 383,58mmT/B, 24lb injecters, long tube headers,big mouth manifold,ported plemum,siamesed runners,ported corvette 113 heads,and 1.6 roller rockers,Good luck.
Look at my sig for mods, i passed the emmission with alvin's chip
in georgia. I adjust 38 psi and engine was very hot.
wow, you passed with all that?
what i did is set the tps to .54 and balanced out the idle speed as well as put back the stock chip. sounds like a plan?
Set the timing at 6 deg and run 10 miles before u jump emmsission station, anywhere tps voltage between .54-.6 will be alright, reduce
some fuel pressure to about 35-38 psi at idle.
i passed it but too close.
good luck
SAMI,
EXCELLENT ADVICE. YESTERDAY I REMOVED MY STAGE 2 CHIP, LOWERED THE FP TO 34.5 WITH FP VACUUM HOSE ON.(IS THAT THE CORRECT WAY?) AND LOWERED THE TPS TO .545 BUT HAD A HELL OF A TIME TRYING TO BALANCE OUT THE IDLE SPEED. I COULD NOT SET THAT TO SPECS AS THE CAR SURGED DRAMATICALLY. DO YOU KNOW WHY? THIS EVEN HAPPENS WITH THE STAGE 2 UNTIL I BUMP UP THE IDLE SPEED.UNBALANCED AIR-GAS RATIO? ALSO, HOW DO I GET A HOLD OF ALVIN FOR A CUSTOM CHIP?
THANKS SO MUCH AND ILL LET YOU KNOW IN A COUPLE OF DAYS THE OUTCOME.
REGUARDS
JOHN
