84, 85 alternator upgrade?
Old Jul 25, 2005 | 09:35 AM
Bilyk's Avatar
Bilyk
Default 84, 85 alternator upgrade?
How many of you upgraded your alternators to the newer style using the tech tip? Was it worth doing?
Old Jul 25, 2005 | 10:35 AM
korvette4u's Avatar
korvette4u
i upgraded to CS-145, reclocked the case to fit .. works great. cost was about the same as CS-105. also installed rear bracket after slight mod(lengthen, reshaped). good luck
Old Jul 25, 2005 | 10:47 AM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Default 84 alternator
I did the upgrade for the '84 model using the tech tips and the alternator would not charge despite replacing it twice. I was told that the jumper wire that was used does not go to the proper terminals to make it work. Had to replace it with a stock rebuilt '84 alternator.
Old Jul 25, 2005 | 04:36 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
No. Replaced mine on my '85 with the stock rebuilt unit 3 years ago. No problems.
Old Jul 25, 2005 | 10:01 PM
Bluevette85's Avatar
Bluevette85
I got the 90-95 ZR-1 Alternator here:
Alternator Express
You must get the ac/delco adapter harness to make it work right.
Works great.
To 84, 85 alternator upgrade?
