MAF problem?? HELP!!!
Old Jul 25, 2005 | 03:47 PM
DEFREGM's Avatar
DEFREGM
Navigator
Default MAF problem?? HELP!!!
89 vette, auto, 82,000 mi. Code 33 exists.
Tried:
No vacuum leak
Burn off relay's changed out several months ago
Checked resistance in injectors cold 17 & hot 18
When hot (220 degrees) it runs like it is only on six cylinders.
Parked in driveway idling and heatsup, then cuts out & difficult o start. When started, the "Service engine" indicator is off and the cars runs even worse.
I disconnected the MAF plug and the car starts and runs OK and the "Service Engine' indicator is lit .
The only thing I didn't do was change the temp. sensor.
What do you think?
should I spend the $$ on a new MAF????
Old Jul 25, 2005 | 04:19 PM
GlennS87's Avatar
GlennS87
Generally, if you unplug the MAF and it runs better than with it plugged, it's time to replace the MAF.
Old Jul 25, 2005 | 05:01 PM
red L98's Avatar
red L98
i have one with no screens of fins you can have for 80$ shipped . it flows alot more than stock
To MAF problem?? HELP!!!
