93 Running Rich
Old Jul 25, 2005 | 09:38 PM
rimler's Avatar
rimler
Default 93 Running Rich
I have just purchased a 1993 Torch Red Convertible 6-Speed Corvette. It has 46800 miles on it. I know the mufflers have been changed out. The car runs around 180 degrees to 209 (With AC on). It has a K&N Air Filter on it. The engine seems to have an idle that may indicate the cam has been changed as well. It runs strong, and I managed to get 27 to 29 mpg on the highway, and averaged 22 mpg during my 450 mile trip to the corvette assembly plant. The issue is at idle and when I rev the engine, it is running rich, I can smell the rich exhause and see the black smoke when I rev it. I am not sure where to start. If it was carb. I would adjust the idle mixture, but this is not that simple. Anybody with experience with this situation would help.
Old Jul 25, 2005 | 09:43 PM
bogus's Avatar
bogus
I guess the first question is this: any codes?
The MPG makes me think it's not serious... so I would start with the easy stuff - O2 sensors and plugs.
Old Jul 26, 2005 | 10:48 PM
rimler's Avatar
rimler
How do I check for codes? I do not have a code scanner for the computer.
Old Jul 27, 2005 | 06:36 AM
conv90's Avatar
conv90
have you an AFPR?
Probably the previous owner raised the pressure without managing the changes in the chip.
-Beppe-
Old Jul 27, 2005 | 04:45 PM
rimler's Avatar
rimler
What is an AFPR?
Old Jul 27, 2005 | 10:38 PM
okies93's Avatar
okies93
St. Jude Donor 06
first thing i would do is get the manuals, this will be money well spent. autozone can pull the codes if any (i've heard)
Old Jul 28, 2005 | 01:26 AM
dizwiz24's Avatar
dizwiz24
Pretty much from what Ive heard. Almost all 93's run rich with cam changes/other mods.
For some reason, all the other years, when mod'd dont have this problem.
You need good tuning. Dont go to Ed Wright. Since my hotcam'd 93 LT1 vert is running rich as heck with Ed Wright tuning.
Go to alvin@pcmforless
Good luck.
Old Jul 28, 2005 | 08:10 AM
conv90's Avatar
conv90
Originally Posted by rimler
What is an AFPR?
Sorry... it's an Adjustable fuel pressure regulator.
-Beppe-
Old Aug 12, 2005 | 05:54 PM
rimler's Avatar
rimler
I did get my car tuned at a dealership. I wanted them to run a scan on it. They did find that #6 Spark Plug wire was shorted out, and another spark plug was not firing all of the time. I had them do a coolant and fuel system flush. They replaced all spark plugs and wires as well as fuel filter and PCV valve. I have replace the egr valve and the selenoid for the egr. Car runs much better but it is still running rich. What should the next step be? O2 sensors? Coil? Or the dreaded Optispark? Any help on the next step would be apreciated
Old Aug 12, 2005 | 05:57 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Do you have a laptop? If so you can buy a cheap ALDL cable from that we can help you diagnose whats wrong.... Or companies like the one I work for can use that data to burn you a chip to address your car's needs.
Old Aug 13, 2005 | 08:32 AM
rimler's Avatar
rimler
I do have a laptop. Where can I get the cable?
Old Aug 13, 2005 | 08:35 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
aldlcable.com or moates.net
To 93 Running Rich
