auto to std swap...
Old Jul 26, 2005 | 10:56 AM
casillas5.0's Avatar
casillas5.0
2nd Gear
Default auto to std swap...
Hi:
Can I install a Camaro T-5 with all tha accesories in a 1985 C4 body Corvette?
How dificult is this?
I know it came with a Doug-Nash 4+3...
Do you know someone who done it before?
Thanks for your help...
Old Jul 26, 2005 | 03:54 PM
kpforce1's Avatar
kpforce1
Originally Posted by casillas5.0
Hi:
Don't know what a T-5 is but why don't you do a T-56 swap if you were wanting to do one? There are direct swap kits I think.
Old Jul 26, 2005 | 07:23 PM
DanZ51's Avatar
DanZ51
Here's a link for the T56 link
I haven't contacted them yet, so let us know what you find out.
Old Jul 26, 2005 | 10:00 PM
casillas5.0
2nd Gear
T-5 is the Borg Warner 5 speed used on Camaro's and Trans-Am's. If the T-56 could be installed, I think that the T-5 will no have any problem. Just need to verify the shifter position in the console and the clutch pedal.
The clutch pedal is a part of the brake pedal assembly or is a separate pedal like in F bodies GM cars?
Old Jul 26, 2005 | 10:18 PM
vette&f-bod lover's Avatar
vette&f-bod lover
just remember,the T5 was NOT installed with 350cu F-bods because of the 350 having to much torque.Some guys I know have put then in their 350's and have run into problems.You are better off going with a richmond,ZF,or T56 which can handle the torque.
To auto to std swap...
