hot
If you want to drop the temps, check between the area between the radiator and the condensor A/C. Change your hoses if they havn't been changed in a couple years. Do a complete coolant flush and replace with 50/50 mixture of distilled and Dexcool.
Its a messy job but will keep your temp down. It works for me.
If you want to drop the temps, check between the area between the radiator and the condensor A/C. undefined Change your hoses if they havn't been changed in a couple years. Do a complete coolant flush and replace with 50/50 mixture of distilled and Dexcool.
You would also need a fan switch or a prom to tell the fans to come on sooner.
A cooler thermostat, alone, won't change the operating temperature. It will only prolong the unhealthy warm up time.
Cooler fan on temps, alone, WILL lower the operating temps. The stock thermostat in the LT engines is a 180°. If the rest of the cooling system is up to it, a 160° stat is NOT required to run close to 180°, which is too cool anyways.
calvette 11,
Your operating temps are not out of line. Your radiator should be kept clean, both inside and out. As suggested, remove the upper radiator shroud and clear the area between the radiator and the condenser. If it hasn't been done in the last two years, thoroughly flush the cooling system and change the coolant. Properly maintained, your cooling system IS adequate.
RACE ON!!!
calvette 11,
RACE ON!!!
I tell you what, I want you to send me a datalog of a LT1 that runs 180 with a 180 thermostat. Or a LT1 with a 160 stat staying at 160 I tell you you won't be able to.. Put a 160 in a LT1 and run it on the freeway, run both fans at full speed, run it in 40 degree weather, etc.. the coldest it will run is MAYBE 175
I said in my post that you will also need the fans on with either a prom or a switch. Did you not read my whole post before calling me assbackwards?
the rating on the thermostat is the temperature which the thermostat starts to get going. Operating temp is usually 10 degrees (if not more) than thermostat temp...
The guy also has a LT1 which is much much different than your traditional SBC. They LOVE to be cool.
Fans control RADIATOR TEMP
Thermostat controls ENGINE TEMP
I said "BASSAKWARDS!", because I feel you got the cart before the horse. Since the stat, alone, won't lower the operating temperature in warm or hot weather, and lower fan on temps will. In short, the stat change, only, does nothing but harm. Fans only can keep the car running cooler. Earlier on fans won't prolong the warm up period, as a cooler stat will.
RACE ON!!!
