nitrous help
Old Jul 27, 2005 | 11:50 AM
flatlne's Avatar
flatlne
Default nitrous help
355 forged bottom,zz9,superram,vig 2600,307rear.Nitrous what is the best complete setup?where to buy?how much to run 150,250,more?
Old Jul 27, 2005 | 05:23 PM
jburnett's Avatar
jburnett
The best setup for a SR is a Fogger setup... One fogger in each runner; plates tend to starve the rear cylinders of fuel on the SR. Same goes for single nozzle systems.
-Jeb
Old Jul 28, 2005 | 05:27 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would not start out with a fogger system unless you know alot about Nitrous or you are a strip car only.
The Barry Grant system works for the every day driver.
Old Jul 28, 2005 | 10:38 AM
jaymitchell01's Avatar
jaymitchell01
Check out the NXL system by NX. It's a direct port setup that comes with a fuel rail that has integrated fittings for both fuel and nitrous. The nozzles go between the injector and the injector housing. I looks like a sweet setup, and would look good if your injectors are exposed.
Old Jul 28, 2005 | 12:02 PM
jburnett's Avatar
jburnett
Will NOT fit under a TPI or SR style manifold. Keep in mind that the fuel rails are underneath the runners bolted to the base manifold and there's very little room under there stock. Both the NX "Nxzle" and the NOS "NOSzle" are both .900" tall; almost an inch which would raise the fuel rail too high for you to bolt the plenum on... You could take an inch worth of aluminum stock and make yourself a spacer plate between the runners and plenum on a SR but that would be impractical in addition to lengthening the runner to that of a standard TPI. Won't work at all on a standard TPI due to the curved runners.
Back to my original post: Plate systems and single nozzle systems plumbed into a SR are sketchy at best because of the SR's plenum/runner layout. Both these type systems starve the rear cylinders which gives you an extreme lean situation and you know what that causes on nitrous. I know this because I've done it... You can stick an EGT in either #7 or #8 and try it yourself and you'll see the EGT's spike very high. For a SR motor the BEST solution if you want to run N2O is a direct port setup. Additionally they are NOT hard to setup or tune; more jets to change, true, but still simple. Follow the mfg's recs if you're inexperienced and you'll never have an issue.
-Jeb
Old Jul 28, 2005 | 02:00 PM
johnnyevans's Avatar
johnnyevans
JEB, Nuff said, don't have to add a thing.
Plates are NOT a good thing for SRs.
Old Jul 28, 2005 | 04:31 PM
jaymitchell01
Originally Posted by jburnett
Will NOT fit under a TPI or SR style manifold. Keep in mind that the fuel rails are underneath the runners bolted to the base manifold and there's very little room under there stock. Both the NX "Nxzle" and the NOS "NOSzle" are both .900" tall; almost an inch which would raise the fuel rail too high for you to bolt the plenum on... You could take an inch worth of aluminum stock and make yourself a spacer plate between the runners and plenum on a SR but that would be impractical in addition to lengthening the runner to that of a standard TPI. Won't work at all on a standard TPI due to the curved runners...
-Jeb
Well nevermind on the NXsle system, he has the same problem I do on my LT5. I would have probably gone with that system if it would fit, oh well...
JB is right though, regardless of your nitrous experience, if you can go direct port, do it. It is much safer for the motor, and the HP gains are much more profound than with a single nozzle.
Old Jul 28, 2005 | 09:03 PM
red L98's Avatar
red L98
-Jeb
thats the best way to do it , do it right and it will live for a long time
To nitrous help
