92 LT1 Starter Problem
Old Jul 27, 2005 | 04:37 PM
rwsduc's Avatar
rwsduc
Default 92 LT1 Starter Problem
Went to leave work today and the car decided I needed to stay longer...
The starter cranked just briefly, then stopped. It's done that a couple times in the recent past, but it would typically start right up on the second attempt. This time, nothing. Tried several times and it finally cranked normally, the engine fired and ran normally, but the starter apparently wouldn't disengage, judging by the horrible whining noise.
I turned the ignition OFF, but the starter kept right on happily cranking away. At one point I even took the key out, but the starter kept going. It finally took several attempts of going between "run" and off before the starter finally disengaged. A split second later, smoke started billowing out from the passenger side. Needless to say, it wouldn't crank over again afterwards.
Never had anything like this happen before. I'm sure I need a new starter and solenoid now, anyone have ideas as to what else I may need to get before I try fixing it in near 100-degree Florida temperatures? Thanks in advance....
Old Jul 27, 2005 | 07:13 PM
Strick's Avatar
Strick
Take a good long look at your battery cables and terminals, you might have overheated them. The starter is fairly simple to remove and replace. I'm not a fan of rebuilt starters, I like new AC Delco's.
Old Jul 27, 2005 | 08:39 PM
rwsduc's Avatar
rwsduc
Thanks Strick, I'll take a look at those too. She's still sitting in a safe parking lot and will probably have to stay there until Saturday morning. I probably don't want to know what a new starter will cost, but I'd rather go that route than rebuilt.
I just put a new battery in a couple months back, but todays event may have smoked it. I need to get in the Helm manual and look at relays and the like. For the life of me I can't imagine any other way it could have stayed cranking with the key OUT of the ignition.
Old Jul 27, 2005 | 10:14 PM
Strick's Avatar
Strick
A wire might have crossed. It was jumping itself
Old Jul 27, 2005 | 10:48 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Hey Tom, try changing a starter on an LT1 with a Canton pan and headers...
Old Jul 27, 2005 | 11:17 PM
jfb's Avatar
jfb
Your starter includes a starter solenoid which pushes the starter gear into the flywheel ring gear and then switches the battery to the starter motor. The contact on the starter solenoid that switches current to the starter motor gets pitted and burned and can weld shut near the end of its life and keep the starter motor running with the ignition key off. It happened to me and I keep a wrench for my battery posts in the car and was able to disconnect the battery and then had my 87 flat bedded to my mechanic. You need a new starter solenoid, but if you want to get it out of the parking lot, I would just replace the starter there. I also had trouble with a rebuilt starter and replaced it with a new one!
Old Jul 28, 2005 | 11:26 AM
Strick's Avatar
Strick
Hi Ransome, long time no hear from you. How's the new house? Got the garage all set up?
Old Jul 28, 2005 | 08:14 PM
rwsduc's Avatar
rwsduc
Must be what happened on mine, I know I probably had a really stupid look on my face while I stood there with the ignition key in my hand watching the engine continue just cranking away. Naturally, I didn't have a terminal wrench with me...
Old Jul 28, 2005 | 10:30 PM
Ramrod92's Avatar
Ramrod92
It's strating to come together. Hardly have time to work on the garage because of having to mow the yard (almost an acre).
Old Jul 28, 2005 | 10:31 PM
Ramrod92's Avatar
Ramrod92
It's starting to come together. Hardly have time to work on the garage because of having to mow the yard (almost an acre) all the time.
To 92 LT1 Starter Problem
