IRS question.
Old Jul 27, 2005 | 06:50 PM
94Polo6Speed's Avatar
94Polo6Speed
Default IRS question.
When i pull my rear end to swap gears will the car still be mobile? (able to be pushed around?) I'm new to irs.
Old Jul 27, 2005 | 07:00 PM
bogus's Avatar
bogus
it depends on how deep you go.
if you take just the halfshafts and such out, maybe.
you see, the halfshafts are a locating link, without them, the rear might sag quite a bit.
what would work are some dollys that the tires could rest on.
Old Jul 27, 2005 | 07:25 PM
CFI-EFI's Avatar
CFI-EFI
Nope. It's worse than that. The strut rods and tie rods anchor to the diff. The wheels will loose all camber control and steer aimlessly.
RACE ON!!!
Old Jul 27, 2005 | 08:32 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Can't move it on the wheels when the rear is out of the car. You can try to move it with supports under the frame....be careful.
Old Jul 27, 2005 | 08:36 PM
VenkmanP's Avatar
VenkmanP
You'll also need to support the tranny if you try and put it on a dolly or something.
Old Jul 27, 2005 | 10:32 PM
aboatguy's Avatar
aboatguy
RACE ON!!!
You forgot the spring!
Every one has given you good gouge if you remove the diff and batwing your car is not a rolling chassis!!!
Old Jul 28, 2005 | 03:13 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The rear diff as mentioned is part of the suspension, and it also acts as the rear attachment points for the drivetrain.
You need to support the trans if you pull the batwing.
Old Jul 28, 2005 | 10:53 AM
CFI-EFI's Avatar
CFI-EFI
I certainly did. That makes it much worse than I was thinking. It won't even sit on the rear wheels, let alone roll on them.
RACE ON!!!
To IRS question.
