Rear end clunk, vibration, maybe even shift.HELP!
Old Jul 28, 2005 | 03:10 PM
jdawgC4's Avatar
jdawgC4
Default Rear end clunk, vibration, maybe even shift.HELP!
Recently I have had some problems coming from the rear end. Seems to be getting worse. The car is a 92 with 93K miles. Here is what it is doing:
1) Knocking, feels like it close to under drivers seat or to the right rear. Usually it is sparatic, either on turns or when starting to take off. It also happens in neutral when coasting. Also can make it have a continuous clunk when going in reverse at 4 m.p.h.
2) Vibration when accelerating and the rear end is under load. Can be felt throughout the whole car.
3) This may just be me but I think the car shifts from left to right in the rear if you are going about 30-45 and just tap the gas. I dont know if this is a related problem or totally different.
Im hoping this is just the universals going but I tried to move the half shafts and drive shaft around and didnt really see any play. I dont know if I tested it the right way though. I put the rear of the car on jack stands. and did it like that. If anything it looked like the play was in the differential.
Please give me some suggestions.
THANKS in advance
Old Jul 28, 2005 | 07:18 PM
jdawgC4's Avatar
jdawgC4
Anybody?
Old Jul 28, 2005 | 07:24 PM
Kinkajou's Avatar
Kinkajou
It would be a good idea to check the wheel bearings.
Old Jul 28, 2005 | 08:11 PM
shadetreeperf's Avatar
shadetreeperf
Could it possibly be a bushing or loose suspension related bolt? The stock rubber doesn't hold up too well. I'm new to the "C4-specific" suspension though. My '85 Iroc with a locker used to do the swaying back and forth thing, and it was the bushings in my Granetelli LCA's. Just a suggestion.
KC
Old Jul 28, 2005 | 09:26 PM
polo91cnvt's Avatar
polo91cnvt
I agree with check the wheel bearings. I had one go and it will effect handling over time, just go a little fast into a corner and the rear end will swap you around faster than you can correct. The half shafts will be ok with very little noticable movement. Best trick maybe go to the noisy side and pull the half shaft.
Good Luck.
Old Jul 28, 2005 | 10:11 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
#3 sounds like the U-joints. Jack up the rear then take a good look around that region. By the way, roll the rear wheels on each side by hand forwards and backwards to see if there's excessive play. If there's wear, you'll definitely be able to tell. Good luck.
Old Aug 3, 2005 | 10:30 AM
jdawgC4's Avatar
jdawgC4
ALL FIXED! It was the universals. Mainly just the one on the right rear wheel side half shaft. The roller bearings were completely missing. It was hard to notice play while rotating the wheel back and forth but then i noticed the half shaft moved in and out. All noises are gone!
Old Aug 3, 2005 | 11:01 AM
DieL's Avatar
DieL
glad you found it.. was gonna say those were the exact symptoms my car had when i broke both of mine !!
To Rear end clunk, vibration, maybe even shift.HELP!
