Headlight Motor Repair
Old Jul 29, 2005 | 04:44 AM
amatykiewicz's Avatar
amatykiewicz
4th Gear
Default Headlight Motor Repair
1996 LT4. Right headlight motor is beginning to fail. Motor continues to run for about 3 seconds after lights open and close. Probably an internal limit switch. Can this be repaired or is a rebuilt/new headlight motor the best option? Can you point me to good repair instructions?
Thanks.
Old Jul 29, 2005 | 05:18 AM
95NOSvette's Avatar
95NOSvette
Everytime mine did "exactly" what you describe, it ended up just being the 3 delrin bushings inside...(5 bucks per light from mid america)..Might not be it but,Have you tried to replace them?
Old Jul 29, 2005 | 06:57 AM
yellowvette94's Avatar
yellowvette94
6th Gear
I have a 94 coupe, mine did the same thing. I replaced the bushings, everything is fine now. The factory bushings are
plastic and will be powder or close to it when you disasemble.
Old Jul 29, 2005 | 09:43 AM
amatykiewicz
4th Gear
That's two recomemdations that I replace the bushings as a first step. Corvette Fever online has a tech report on replacing the bushings so I'll try it. Thanks.
Old Jul 29, 2005 | 09:48 AM
69mako's Avatar
69mako
I replaced mine in about 2 hours start to finish...you'll need to get a small pin driver to knock out the gear pin from the motor shaft and use a good light grease when you put it back together
Old Jul 29, 2005 | 02:37 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like a bushings issue to me, too...
Old Jul 29, 2005 | 11:57 PM
champ's Avatar
champ
Bushings!!!
Old Aug 5, 2005 | 03:32 AM
Togo's Avatar
Togo
how would you know if it's bushings or (i thought they had) nylon gears - and they should be switched out for metal
mine is doing it too - and tonight, the light got stuck UP on the passenger side - and it will occassionally go down but not come all the way back up when lights are turned back on
Old Aug 5, 2005 | 10:26 AM
jerkyboy's Avatar
jerkyboy
I replaced mine last night. One side took me 1.5 hours start to finish. The plastic gear itself was not damaged at all. The bushings were dust There a two articles on the Tech Tips that proved very useful. As noted above, make sure you have a punch and also a LONG #30 torx bit. My bit wasn't long enough and that slowed me down
Light works like a charm now!
Old Aug 5, 2005 | 11:22 AM
onedef92's Avatar
onedef92
It's your bushings! Here's the Corvette Fever article. http://www.corvettefever.com/howto/33098/
Also, check out the TechTip in C4 section by Jeff Landis. His instructions are dope. It's a good weekend project. Good luck!
To Headlight Motor Repair
