Ltpws
Old Jul 29, 2005 | 04:49 AM
amatykiewicz's Avatar
amatykiewicz
4th Gear
Default Ltpws
1996 LT4. Car came with Goodyear run-flat tires. Has Goodrich g-Force tires now and no sensors. Is there a simple and inexpensive way to turn the "SERVICE LTPWS" dash light off?
Thanks.
Old Jul 29, 2005 | 08:25 AM
mseven's Avatar
mseven
Thanks.
When I did the same thing on mine the light never went on and no problems. I would first see if a quick disconnect of the neg. batt. cable changes that, if not I know you can remove the bulb from the DIC, or remove the fuse. I'm not sure if there are any differences between a 90 and a 96 in the LTPWS. system aside from the sensors themselves.
Old Jul 29, 2005 | 09:37 AM
amatykiewicz
4th Gear
The owner's manual says to take it to the dealer. My regular mechanic says the dealer will "burn and install a new chip". That sounds pricey. I have the car for sale and a warning light on the dash makes buyers skittish even when I explain. I am hunting for a cheap, simple fix.
Old Jul 29, 2005 | 02:05 PM
mik's Avatar
mik
Default Ltpws
Take the bulb out of the DIC
Old Jul 30, 2005 | 01:15 AM
vanduker's Avatar
vanduker
http://www.grandsportregistry.com/te...ltpws_bulb.htm
Old Jul 30, 2005 | 01:26 PM
Perfusion's Avatar
Perfusion
Thanks.
I pulled the bulb in my 96LT4 as well - much cheaper than the $400 the dealer wanted to "deactivate" the system (which probably would have just meant pulling the bulb)!
Old Jul 30, 2005 | 11:16 PM
STEVEN13's Avatar
STEVEN13
I took Bulb out in mine in 2001. No problems! This feature (I am almost sure) is a stand along system not tied with the ECM.
Steven
Old Jul 30, 2005 | 11:19 PM
Red Tornado's Avatar
Red Tornado
or you could do what i did......put some electrical tape on the underside of the DIC cover, over the words "service ltpws" - from then on, when the bulb lights up you won't see it
Old Aug 4, 2005 | 08:35 AM
FDAMFA's Avatar
FDAMFA
Take the bulb out> I did only takes a few minutes, very easy to do. Light is gone now
To Ltpws
