Oil dipstick problem
Old Jul 31, 2005 | 09:50 AM
Rich85's Avatar
Rich85
Default Oil dipstick problem
This may sound like a strange problem, but has anyone not been able to get the dipstick back into the tube? I changed the head gaskets on my '85 recently and to get the stock exhaust manifolds in and out, I removed the dipstick but left the tube attached to the engine. After putting the exhaust manifolds back on, the dipstick would only go in about a foot. I tried putting different bends and twists in the dipstick, and even narrowing the tip of it, but its still a no go.
I am able to pass a thin piece of wire down into the pan through the tube. The tube itself is stuck into the pan tightly. I don't think I can remove the tube without breaking it or having to drop the oil pan.
Any thoughts or helpful hints?
Old Jul 31, 2005 | 10:14 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Sounds like you bent the tube a little.
Old Jul 31, 2005 | 10:16 AM
goldeneye_vet's Avatar
goldeneye_vet
Put headers on last year and mine was broken about 3 inches from the end of the hole. I had to pull the pan in order to remove what was left of the dipstick tube. It was like the end of the tube has a shank or something in it and easy removal just isn't in the cards. I beleive you are going to have to pull the pan.
Old Jul 31, 2005 | 10:17 AM
Rich85's Avatar
Rich85
I thought that at first but I inspected the tube and there are no kinks in it. It lines up with the hold down near the starter and the tang that hooks on an exhaust manifold stud.
Old Jul 31, 2005 | 10:19 AM
Rich85's Avatar
Rich85
I was afraid I'd have to drop the pan.
Old Jul 31, 2005 | 05:57 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Turn the engine over a bit and see if you might be hitting a rod or some part of the crank.
Old Jul 31, 2005 | 09:58 PM
Rich85's Avatar
Rich85
running the engine makes no difference.
Thanks for all the info
Old Aug 1, 2005 | 01:10 AM
artvette's Avatar
artvette
Did you try putting some oil on the dipstick and into the tube?
Old Aug 1, 2005 | 05:43 AM
86PACER's Avatar
86PACER
Old Aug 1, 2005 | 08:36 AM
Rich85's Avatar
Rich85
Yes, I tried oiling the dipstick. It didn't seem to help.
The dipstick has always been difficult to get in and out of the tube since I bought the car in '97.
I can pass a thin wire through the dipstick tube but I needed to put a little bend in it right at the tip. It feels like there is a lip or something partially obstructing the end of the tube. I don't know what it could be, unless it's just the angle at which the tube enters the pan.
To Oil dipstick problem
