86 Hatch won't Open
Old Aug 1, 2005 | 03:04 PM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Default 86 Hatch won't Open
Is there a secret to opening the rear hatch when the switch doesn't open it? Fuse is good.
Frank
Old Aug 1, 2005 | 03:05 PM
scorp508's Avatar
scorp508
There is a small pullcord behind the carpet underneath the center of the luggage shade.
Old Aug 1, 2005 | 03:06 PM
89C4L98's Avatar
89C4L98
there should be 3 switches. One on the back of each door and one in the glove box. Did you try all of them?
Old Aug 1, 2005 | 09:12 PM
mikenfl's Avatar
mikenfl
.....and can you hear the solenoid click?
Old Aug 1, 2005 | 09:15 PM
NitrousSam's Avatar
NitrousSam
Default Hatch
Thanks for the insight. I have my engine and battery out and was wondering how to pop the hatch. I will take a closer look at the pullcord. You may have just saved me from having to hook the battery back up.
THANK YOU!
Old Aug 1, 2005 | 09:50 PM
scorp508's Avatar
scorp508
No problemo!
Old Aug 1, 2005 | 10:23 PM
rightofway's Avatar
rightofway
i got to use the pullcord the other day because my batt is dead and i needed a place to put the roof other than the driveway thanks forum.
p.s. is there supposed to be a loop or something on the end of the cord because i had to use pliers to get a grip
Old Aug 2, 2005 | 03:08 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Thanks guys, I'll try the rip cord in a few minutes.
Frank
Old Aug 2, 2005 | 12:49 PM
Plasticman's Avatar
Plasticman
Just as an FYI:
I had the hatch release solenoid go bad on my 87 (no click, no nothing). It had broken an internal wire at what I think is a thermal fuse. Since I don't tend to hold the hatch release button down forever (and therefore overheat the solenoid), I decided to delete the fuse, and reconnect the wire. Solenoid works just fine now (and has been for the last 4 years since I made the repair).
And yes, I found the Pull Cord to release the hatch (I was surprised that GM added such a common sense measure!).
Plasticman
To 86 Hatch won't Open
