GM wheel number
Old Aug 1, 2005 | 10:32 PM
etteroc27's Avatar
etteroc27
Default GM wheel number
Can anyone tell me what this wheel originally fit? The no. cast in it is 9592880. It has a GM cast on the front of it, and the size, 17x9 J 50 cast on one of the spokes. It is a five spoke ZR1 type rim. Thanks for any help. Tom
Old Aug 1, 2005 | 11:57 PM
bogus's Avatar
bogus
front of a ZR1, or, any position on a 1988 to 1996.
Old Aug 2, 2005 | 01:07 AM
skeet's Avatar
skeet
Sounds like it came from a Camaro because the Vettes came with 9 1/2" and the camaro came with 9' wide. Also vettes were 56mm offset
Old Aug 2, 2005 | 02:20 AM
VenkmanP's Avatar
VenkmanP
F body. 96-99 I think.
Old Aug 2, 2005 | 07:18 AM
etteroc27's Avatar
etteroc27
Thanks for the info. Will it work for the front of a 95 corvette with no problems? Tom
Old Aug 2, 2005 | 09:49 AM
mikey whipreck's Avatar
mikey whipreck
If it's an OEM ZR1 wheel, then I'm pretty sure it has a 38MM offset...
If your '95 is a not a zr1, the offset should be 56MM...
so it'll fit, but it's might stick out a little.
Old Aug 2, 2005 | 02:17 PM
VenkmanP's Avatar
VenkmanP
It's only 1/4". Probably not noticeable.
Old Aug 2, 2005 | 02:19 PM
VenkmanP's Avatar
VenkmanP
Aftermarket wheel companies always list 93-03 Camaro and 88-96 vettes using the same wheels, so it should be fine.
Old Aug 2, 2005 | 04:38 PM
bogus's Avatar
bogus
that offset is for the rear only... hence my original post regarding the front of a ZR1 or all the way around on others.
Old Aug 2, 2005 | 04:44 PM
mikey whipreck
ah I see. I didn't know that
Old Aug 2, 2005 | 04:46 PM
gslotman's Avatar
gslotman
I agree with Skeet I owned a 97 WS-6 TA and the rim width was 9 inch F/R.
Old Aug 2, 2005 | 11:21 PM
etteroc27's Avatar
etteroc27
Thanks, Guys. I am going to put tires on them and try them on the front of my car. Tom
To GM wheel number
