specs on 85 engine parts???
Old Aug 2, 2005 | 02:57 AM
ladystoy69's Avatar
ladystoy69
Default specs on 85 engine parts??? updated
wented to know how many teeth on the flexplate of a 85 vette .
also are these the year with the reverse rotation water pump?
thanks in advance
jerry
Old Aug 2, 2005 | 03:16 AM
Morley's Avatar
Morley
153 & no.
Old Aug 2, 2005 | 11:33 AM
CFI-EFI's Avatar
CFI-EFI
153 & Yes.
All C4s came with 153 tooth flywheels or flexplates.
On any SBC Chevy engine with a serpentine belt, the water pump turns in the opposite direction of one driven by a vee belt.
RACE ON!!!
Old Aug 2, 2005 | 11:49 AM
Morley's Avatar
Morley
Originally Posted by CFI-EFI
153 & Yes.
RACE ON!!!
My bad, I was thinking reverse flow.
Old Aug 2, 2005 | 02:16 PM
ladystoy69's Avatar
ladystoy69
any reason i cant replace flexplate with a 163 tooth model besides having to change the starter as well? any problems with that ?
as i cant find a 153 tooth flexplate for my stroker only 163.
also anyone know the factory diameter of flexplate?
thanks
Old Aug 2, 2005 | 02:29 PM
CFI-EFI's Avatar
CFI-EFI
Make that 168 teeth. I ASSUME you have an externally balanced, two piece rear main seal, stroker, crankshaft. There is no reason not to make the substitution. The flexplate will fit. A 168 tooth flywheel will not. You can simply change the nose piece on your existing starter, if it is otherwise in good condition. Make sure your block is drilled and tapped with all THREE starter mounting holes.
RACE ON!!!
Old Aug 2, 2005 | 02:34 PM
CFI-EFI's Avatar
CFI-EFI
thanks
You edited while I was answering. The 153 tooth 'wheel is 12 3/4" in diameter, and the 168 toother is 14".
RACE ON!!
To specs on 85 engine parts???
