Issues with 84 - fuel problem
This is what has been done over the last week and a half.
New fuel pump - the reason why they startd working on it
After the install.... He is telling me it rained that night, and the following issues started the next day.. Perhaps a short somewhere?
Started car and it would die.
They replaced ECM/ chip - started car and still dies.
Replaced TPS switch and set to corret voltage - start car and dies.
They tested the fuel pressure - once the pedal is pressed, the pressure falls to around 3-4 psi and car dies. They disconnected the fuel return line, plugged it.. car runs fine.
Thats about all i know guys... Can someone please give me a place to start with this? My friend is doing this work on a car for a man who has terminal cancer - it was the guys dream to own a vette... This is standing in the way of enjoying it. I appreciate any kind of feedback!!
Thanx!!
tank -> fuel pump -> filter -> front TB -> rear TB with regulator -> tank
The fuel pump creates a fuel FLOW.
The regulator works like a valve restricting the flow back to the tank and that builds the pressure between the pump and regulator.
Where do you measure pressure?
Do you have the front and rear TB mixed somehow?
ideas/ comments?
Thank you!
I once had a similarly perplexing problem. There was a leak in the hose, inside of the tank, leading from the pump to the metering unit flange. It wouldn't cost anything to take a look.
RACE ON!!!
Total freak thing.. There have been 5 mechanics working on this car trying to figure it out.. Replaced ecm, tps, chip, fuel pump twice, regulator, and got nothing. Needless to say, the car should be finished tomorrow and returned to the current owner.. Thanks for the insight guys! It is greatly appreciated...
quicksilver458, I'm glad the fuel problem is fixed.
I remember with mine, it went to a shop three times to fix it before they finally told me they thought it was an ECM problem. Thats when I told them to stop working on it and went and got it myself. Turned out they said they had put two pumps in it (the first one being defective) I don't know if they did or not. I have doubts they ever put a second pump in. I hooked a fuel gauge in front of the filter with enough line for a friend to hold it outside the passenger window and went for a spin... It would run a constant 9lbs, then, all of a sudden, drop to like 2-3lbs and finally quit. Sometimes it would hold the 2-3lbs for awhile, sometimes not. Everytime, I could here the pump running after the car quit, so I knew it should have been pumping. Capping the return line, I would pull a constant 13lbs off of the pump (thus, my question to CFI-EFI) but with the regulator, it was only 9lbs.
Long story short, I diagniosed a bad pump, pulled it and put in an 85 Carter pump from NAPA. It's been runnig great ever since. I never tested the pressure with teh return plugged on the new pump, but it does put out a constant 10lbs now - under load or not, where my old pump would drop to 5-6lbs under load. It's got the regulator pegged
My next missin is to modify the factory regulator to make it adjustable and bump up system pressure to about 12lbs...That was when I learned never to take my car to a shop anymore. A hard lesson, but one I think we all come to learn after awhile...
And that also reminds me to thank everyone on this forum. This forum is full of the most helpful enthusiasts that I have come across anywhere and I'm grateful that I found it.
RACE ON!!!
That would be a bad place for a fuel leak... so close to the exhaust pipe and all...
The tee clears everything. It is 45° inverted flare at each end and tapped for 1/8" NPT in the middle. I slide the 45° inverted flare nuts onto the fuel line tubing and double flared the tubing. The fuel line connections at the tee are the same as at the TBs.
RACE ON!!!
Now IF you do need a new pump, a later pump is a good idea.
RACE ON!!!
