Where to start?
I hope it's not too used.Things to add to your list:
Flush cooling system
Replace thermostat (160-degree works well)
Replace surge tank cap
Replace plugs and wires
Examine vacuum lines
Flush the transmission and cooler (Auto?)
Clean out from behind the radiator and condensor
O2 sensors may be close to death (?)
BTW, Welcome to the forum!
Blake
The advertising claims of 20-30hp increases with the purchase and installation of airfilters/airfoils/catbacks/thermostats/pulley sets/plug wires/etc/etc can be ignored.
For the power increases you are looking for, you WILL be spending significant money and doing some major wrenching/tuning on your engine.
The cheapest route for you would be nitrous, but that will still require paying someone who knows what they are doing to set it up (if not to install it in the first place).
There is no free lunch and no easy horsepower.
Let us know how it goes!
Larry
code5coupe
With long tube headers and that Flowmaster you will easily get 350+ RWHP. If you have to use shorty headers you might still get there with good tuning.
Doesn't TPIS offer long tube headers for the LT1?
Congratulations though and have fun with it!
You might get the kind of power you are looking for out of your 118K mile engine...for a while.
If you want to get significantly more power out of your engine, you must start with a solid foundation. That means a bottom end that is stout; at least a fresh stock setup.
Aidoneus is right; you are, unfortunately, looking at those very major operations you wanted to avoid.
Larry
code5coupe
I would just do a top end package. While you are in there you could change the rings on your pistons and maybe do a hone to freshen the bottom end up. But that will be even more money.
You should really spend your hard earned dollars on a head and cam package. Ligenfelter is really expensive but I am sure they do quality work. Why don't you check out:
www.eportworks.com
Lloyd Elliot will ship you a head/cam package that will make awesome power for a great price. LT1 Camaro guys love him.
Then contact Alvin at:
www.pcmforless.com
He will mail you a tune for your modifications. He is very familiar with Lloyd's packages. You will have to buy a piggyback adapter for your ECM to install the new chip. But they are reasonably priced and Alvin can help you out there.
Your biggest problem is getting long tube headers to pass California visual emmissions inspection. Exotic Muscle sell geat long tubes for our cars with all the emissions hook ups (O2 bungs etc..). But you won't pass a visual with them. You might have to settle with shorty headers (Hooker sells them I believe).
Just tell Lloyd and Alvin your are running shorties and see what they say. Once you get the heads, cam and chip mailed to you, find a good shop who can install them.
Trust me with a head/cam package and a good tune you will be making awesome power you can feel. I did the same thing to my 92 and I dynoed 371 HP to the wheels which is equivalent to about 430 HP at the flywheel.
BTW I went with Total Engine Airflow for my heads. You might want to check them out as well. Great LT1 heads at a good price. But if I had to do it all over again, I would go with Lloyd's heads and Alvin's tune. Just don't get to greedy for power and stick to Lloyd's Stage 1 or possibly his Stage 2 package. You want your car to be streetable, Stage 3 is more for drag racing.
It also doesn't make sense to me to just hone the cylinders, at that point, in the grand scheme of things, you're not that far from doing the whole job. I just had my L98 bored out (and it was even within tolerances!) and it cost me about $500 to have it bored and decked. I'm going through the exact same thing you are with 93K on my motor and it purred like a kitten too, but I figure I'd rather build it right from the bottom up than pay for top end now and possibly pay for all the same work again later plus the bottom end, and as Murhpy's law would have it, you know something would fail at the most inconvenient time. My only regret is maybe I should have just stroked it to 383 while I had the block out, but frankly i'm a little terrified of my next credit card bill as it is.......
If you are planning to keep the car for a while, my advise again is to just bite the bullet and do the job right. What you think you will be satisfied with now in terms of power, will ultimately not be enough. It would be a great comfort if you decided to boost the power later knowing you already built the bottom end to withstand it. Just my $.02
Frankly, it didn't occur to me. I personally just had the crank checked and it was well within tolerances, so I just had it polished and reused my stock crank, but did I miss a good opportunity for more horsepower?
You're going to need new pistons if you bore the block. I don't have any suggestions for the LT1 though, I'm sure someone else will chime in.
