Check Engine Light means......
Old Aug 4, 2005 | 07:28 PM
shane99's Avatar
shane99
Default Check Engine Light means......
I have a code 26 set from the ECM. I know what the issue is and am persuing getting a chip burnt to remove it. Ill also haul out the EGR and have that code dealt with.
The Helms manual does not speak to if there is ANY reason for the Check Engine Light on if that doesnt allow for the car to go into closed loop?
Old Aug 4, 2005 | 10:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does the light come on when driving or at startup??
Old Aug 5, 2005 | 01:18 AM
shane99's Avatar
shane99
After about 3 minutes of driving when warm, about 5 when cold. Code always shows as Historic
Old Aug 5, 2005 | 02:31 AM
korvette4u's Avatar
korvette4u
hey 65Z01, give him the diode fix. worked for me. did not have to reprogram ecm.
Old Aug 5, 2005 | 01:36 PM
audible's Avatar
audible
Whats a diode fix??
Old Aug 5, 2005 | 05:58 PM
shane99's Avatar
shane99
Maybe a diode fix is something electronics junkies do!
To Check Engine Light means......
