Crank / Rods / Pistions
Old Aug 5, 2005 | 08:25 PM
RFDrpm's Avatar
RFDrpm
Default Crank / Rods / Pistions
So ive decided to pull the motor and do the whole thing from the bottom up. So any suggestions on Crank, Rods, & Pistions. I dont want to stroke it, but I do want the best for my baby.
Old Aug 5, 2005 | 08:31 PM
Pete K's Avatar
Pete K
Do you need the best? If the best is needed, I would suggest a Crower billet crank. They are a mere $2,300 dollars. A $1,300 set of Oliver rods would work well. Top it off with a $1,000 set of custom JE pistons and you should be set.
Old Aug 5, 2005 | 08:35 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
http://www.cnc-motorsports.com/default.asp
Old Aug 5, 2005 | 08:49 PM
CFI-EFI's Avatar
CFI-EFI
What was so awful with what was in there? Are the crank and rods unusable?
RACE ON!!!
Old Aug 5, 2005 | 11:06 PM
RFDrpm's Avatar
RFDrpm
Nothing is wrong with them, I just plan on making in the 400hp range and want a bottom end that hold up to some serious usage. From what I have seen I can get the whole set up for $500 with the link that was provided. I dont speak engine so would some one explane to me what bore stroke and all these # mean. I know how a motor works and how to assemble it, but the mathmatics I havent learned yet.
Old Aug 6, 2005 | 08:33 AM
Pete K's Avatar
Pete K
I have been making similar or slightly more power than that for about 13 years. You do not "need" much more quality than stock parts deliver. Most poeple would recommend forged pistons. SRP makes a great piston for not alot of money. If rpms are kept below 6500, a cast crank, remachined and balanced of course, can be used. Lots of options out there. Let your wallet decide. Remember though. Buying expensive parts give you better odds of living a long life. The money does not buy guarantees.
Old Aug 6, 2005 | 12:32 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by Corvette Kid NC
They offer one helluva deal. For $7.95, you can purchase "free shopping". I wonder what other freebies you can BUY?
Bore is a word. Stroke is a word. Words are not mathematic expressions. They, like other words, simply have definitions. I am puzzled as to how you can assemble an engine without knowing certain basic terms. Where, for instance, when you assemble an engine, do you install the piston(s). The answer is not mathematical.
RACE ON!!!
PS. $500.00 will not buy you, "the best for my baby."
Old Aug 6, 2005 | 06:54 PM
RFDrpm's Avatar
RFDrpm
You are correct $500 won't buy the best, but I don't plan on making over 650 hp so what do I need a crank that is rated for that kind of power for? I just want to get good quality parts that have been proven.
This is what I saw on the website:
Sb Chevy 350 Eagle Cast Steel Crankshaft - 3.480" Stroke, 2pc Seal $ 165.00
Chevy 350 W/ 5.7" Rods, -4.8cc Flat Top Keith Black Forged Pistons
Options: Bore size: .030 $ 332.93
Subtotal: $ 497.93
My mathmatical question is what do the different #'s mean ie: 3.480" stroke, -4.8cc, and .030 bore, and how do they relate to eachother and my engine.
Old Aug 6, 2005 | 07:49 PM
rrubel's Avatar
rrubel
Ok, first things first. You might want to learn more about your engine by reading some of the tech notes on this site.
- You've got a 1-piece seal (2-piece ended in 1985) so that crank won't work.
- Unless you're going to a larger cylinder bore, you don't need .030 overbore pistons.
- A cast steel crank shaft is no better than what you have, which is probably fine. You'll be able to put a serious amount of horsepower through it.
This is not a project to enter into lightly. I learned that the hard way, so I'm just warning you... do a LOT of research ahead of time, and know what you already have BEFORE you start looking at new stuff. It'll save you a lot of time.
[RICHR]
Old Aug 7, 2005 | 02:01 AM
Corvette Kid
I didn't have any complaints about paying a $7.95 handling fee to get a crank, rods, pistons, rings and bearings delivered, and at a very good price.
Old Aug 7, 2005 | 09:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
You can get a Scat 4340 crank for just over $500 bucks; it's a pretty stout piece. Or, Calies makes a Dragonslayer crank that's a few undred more. Not going to break that! As CorvettekidNC posted Crower makes some real trick pieces too, in all different weights. They are pricy. but if you want the best...How deep are your pockets? Make sure and get a high quality forgeds piston such as SRP/J&E, Mahle, etc. Many of these come with a trick antifriction coating on the skirts. Ceramic coating is available too. Sky's the limit pretty much.
Make a gameplan, set your budget and build it.
Old Aug 7, 2005 | 12:31 PM
CFI-EFI's Avatar
CFI-EFI
I'm not saying that is a bad deal, but when I ran across the banner, headline, or whatever, proclaiming, "FREE SHIPPING!...Only $7.95", I had to laugh at the irony of it all. I'll bet for $500.00 you can get a "free" crankshaft. Plus $7.95 for free shipping, of course. I guess you had to be there.
RACE ON!!!
Old Aug 7, 2005 | 12:38 PM
Corvette Kid
RACE ON!!!
I know what you're saying, I just felt like giving you some crap!
Old Aug 7, 2005 | 12:53 PM
CFI-EFI's Avatar
CFI-EFI
I have no idea. It wasn't me that proclaimed, "but I do want the best for my baby." in the opening post.
Subtotal: $ 497.93
Exactly why are you pricing these parts, that you don't if they will fit your engine or not? Is your crank shaft bad? Does it need replacing? How about the rods? How about the pistons?
If you don't know what the numbers mean, why have you picked these parts? You really need to go back to square one. You need some basic engine schooling before you undertake a project like this.
The rest of your comments make this very hard to believe. How can you assemble an engine without using numbers? How do check clearances? When you're done, how do you know what size engine you've just finished building?
RACE ON!!!
Old Aug 7, 2005 | 12:57 PM
CFI-EFI's Avatar
CFI-EFI
You must have cheated and butted into line. The line to give ME crap, is longer than that.
RACE ON!!!
Old Aug 7, 2005 | 04:01 PM
Caboboy's Avatar
Caboboy
RACE ON!!!
Old Aug 7, 2005 | 06:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might benefit from a book on SBCs but Dave Emanuel or Dave Vizard; they explain about parts selection for our SBCs.
When doing a rebuild I think that you will want to have the cylinders align bored and honed and the block decked as well as some other machining. Also you will need to decide on compression ratio you want and do some math on what various decisions, like head work, will bring.
When doing the math I find it convenient to change the dimensions to metric first. FYI the basic calculations of interest are:
CR=Vt/(Vf), where Vt=Vf+Vd
Vt=total volume
Vf=fixed volume (chamber volume+deck volume+gasket volume+piston top dish volume+volume from piston top to compression ring)
Vd=displacement volume
volume = length * area
area = (diameter/2)**2 * 3.14159
Have fun with the rebuild, it sounds like a fun project.
To Crank / Rods / Pistions
Old Aug 7, 2005 | 06:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
RACE ON!!!
That's a personal question; what was her answer to *THAT *?
your friend
Old Aug 7, 2005 | 07:55 PM
CFI-EFI's Avatar
CFI-EFI
your friend
Friend...THIS!!!
RACE ON!!!
Old Aug 7, 2005 | 08:07 PM
Corvette Kid
Friend...THIS!!!
RACE ON!!!
Whoa! Y'all are gonna drag this thread to OT!
