Bad ECM on 92?
Old Aug 6, 2005 | 09:03 AM
stanandsue's Avatar
stanandsue
Default Bad ECM on 92?
92 convertible was running fine Mon-Tue-Wed. I started it Thur morning and SERVICE ENGINE light on. Speedo wouldn't read anything but zero. Engine hesitates on accel. Shorted A-B and got only SYS flashes. Shorted A-G and got codes: with small '1': C41, H41, H72, ---, with small '4': Err, then with small '9' got H65, H72, --- then small '1.0' I think this means that my electronic spark timing has a bad connection or bad box, or my ECM needs replacing. Why 'Err'? Any suggestions?
Old Aug 6, 2005 | 07:49 PM
bogus's Avatar
bogus
oooh... "ERR" means that the CCM cannot communicate with the ECM.
That is not good.
Now, when you jump A-B, the SES should flash... SYS flashes sound like an error.
The C41 (C=current) means that the CCM has lost contact with the ECM.
Read this: C4 Guru - Pulling CCM Codes 1992-1993
Old Aug 7, 2005 | 08:19 AM
stanandsue's Avatar
stanandsue
thanks - I'll try it today.
Old Aug 8, 2005 | 06:46 AM
stanandsue's Avatar
stanandsue
So . . . I did the in-depth code pulling on my 92 and everything in sec 1.x looked consistent with earlier codes (above), detail troubleshooting found nothing wrong. Likewise section 9.x looked same for 9.1 and 9.7. 4.7 showed the end code '- - -' but 4.1 just showed 'Err'. I disconnected the batt, disconnected and pulled the ECM and pulled out the PROM, then reseated it. When I put it back together, I got C12 to start sec 1.x, but still got 'Err' at 4.1. Is the ECM definitely bad?
Old Aug 8, 2005 | 06:51 AM
Tom Piper's Avatar
Tom Piper
The problem you mention is usually a defective ECM on vehicles up to the ECM change in '94 -- the '94 and up do not seem to have as many ECM problems.
This problem is hard to pin down between the ECM and CCM while trouble-shooting, but the ECM is usually the culprit.
Tom Piper
Old Aug 8, 2005 | 11:03 AM
Nathan Plemons's Avatar
Nathan Plemons
I had the ECM go out on my 92. I could be driving it an basically every gauge would freeze where it was, including the tach. Every idiot light in the car would come on. It would still run but it was most certainly in "limp home" mode, which is far less than optimal with my modifications. It had a very bad stumble on acceleration, etc. It would do that to me and then if I hit a big enough bump it would go away. I replaced the ECM a few years ago and haven't had any trouble since.
Old Aug 8, 2005 | 12:53 PM
bogus's Avatar
bogus
It's time to replace the ECM.
I gave you that document as a way to decypher the codes. Not so much for procedures.
Old Aug 8, 2005 | 01:05 PM
stanandsue's Avatar
stanandsue
thanks - I'll start looking for an ECM
Old Aug 8, 2005 | 03:29 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Try www.tld-corvette.com They usually have them in stock for ~$150.
Old Aug 8, 2005 | 03:40 PM
onedef92's Avatar
onedef92
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like a an ECM stroke to me...
Old Aug 8, 2005 | 07:38 PM
stanandsue's Avatar
stanandsue
thanks - they had them for $157 plus a $125 core charge and free UPS ground.
Old Aug 9, 2005 | 07:17 AM
Tom Piper's Avatar
Tom Piper
Make sure you keep your EPROM out of your old unit to put in the new one.
Tom Piper
Old Aug 10, 2005 | 12:03 AM
Nimrod's Avatar
Nimrod
From: Willow Glen, California......................"But... Chunks is our dog!"
That is not good.
Sorry to jump in here, but my '92 showed all of these symptoms. I replaced the ECM with one from tld-corvette.com and nothing has changed, except instead of running crappy, it doesn't run at all. Same codes, same Err. message. Now what?
Old Aug 10, 2005 | 12:50 AM
bogus's Avatar
bogus
that tells me there may be a harness problem that needs to be chased down.
Old Aug 10, 2005 | 12:56 AM
Nimrod's Avatar
Nimrod
Thanks Bogus!
That's what I figured (was afraid of).
Nice CCM Code reading write-up BTW!
Old Aug 10, 2005 | 01:57 AM
bogus's Avatar
bogus
sorry for the bad news....
glad you liked the write up!!! We aim to please!!!
Old Aug 10, 2005 | 01:38 PM
test's Avatar
test
Bogus that was a great .pdf on pulling error codes. I have been going crazy trying to find that information.
Does anyone know why the word "SYS" would flash on the digital display?
To Bad ECM on 92?
Old Aug 10, 2005 | 02:40 PM
Tom Piper's Avatar
Tom Piper
The Check Engine light is the indicator that there is a problem detected by the ECM.
The SYS indicates there is a problem detected by the CCM.
Tom Piper
Old Aug 10, 2005 | 02:48 PM
bogus's Avatar
bogus
what would really bother me is if the CCM is throwing a SYS without a code behind it!!!!!
Old Aug 10, 2005 | 02:49 PM
bogus's Avatar
bogus
Glad you liked it!!!!
