Need advice on cat
Now here is the important stuff. I bought the car last Wednesday and I had it in the shop all day Friday for evaluation. My first mistake was not having it in the shop prior to purchase but I won't go there. Here is what they found:
1) Needs Brakes and Rotors all around
2) Needs ball joints up front and it looks like this means control arms? they look attached and riveted.
3) Needs catalytic converter. The one in it has separated and you can hear it banging inside.
4)Needs new emergency brake cables
5) Rear callipers
Well luckily I did not overpay for the car and I plan to have all the work done. Do any of you have suggestions on what replacement parts I should go with? Is there a cat that will allow for more than stock airflow? Should I go with slotted rotors?
Any suggestions on where to get all this stuff without taking a second mortgage.
Oh, did I mention the small oil leak
Thanks as always!
Paul
