PS Rack fitting?
Old Aug 7, 2005 | 12:11 AM
rodj's Avatar
rodj
Default PS Rack fitting?
Looking for a source of an adapter fitting to change from the factory flare that takes a "O" ring to a normal taper flare on the pressure line input to the GM rack.These apparently exist but not in this part of the world.
I am cleaning up my RHD conversion done by others and want to replace the large hose with a 3/8 steel line as all my plumbing has to run to the otherside of the engine under the balancer and clearance is a problem.
No one in these parts has the equipment to make the std flare so an adapter was suggested.The std fitting is a larger version (20mm) of the ones used on the fuel lines (16mm)where they join the rail.
Any one work in a power steering shop?
Old Aug 7, 2005 | 03:28 AM
RatC4's Avatar
RatC4
Default Try Earl's?
Looks like they have a branch down under
http://members.ozemail.com.au/~earls/adaptors.htm
Old Aug 7, 2005 | 08:51 AM
rodj's Avatar
rodj
Thanks will check it out.
Have a Russell catalogue but could not find anything that would get me from the GM PS fitting to a regular flare or AN fitting.Problem is down here shops only carry more popular items mainly fuel type fittings.It's a case of it"s in the catalogue but we don't have it.
Old Aug 7, 2005 | 11:22 AM
RichS's Avatar
RichS
DRM sells a hose kit that has all the proper fittings for $100.
To PS Rack fitting?
