[LT1] Top end performance upgrades- $500
I figure that my head gasket replacement alone should be $800-$1000 so why not make the most of it by throwing in some fun stuff.
ps. I see you are in syracuse. If you can come to Rochester. I have a friend can install the cam and tune your car for far less than you take it to the shop out there. I am sure he can do it all head gasket, cam install and tune your car for under $1000, of course you provided the gasket and cam kit. He is a hard core corvette enthusiast know what is doing. Let me know if your interested.
Bruce
Bruce
If you could PM me the contact info on your friend that would be great.
The interesting thing about the LT1 is that GM actually did everything they could to get the most out of it in stock configuration. When I put on my headers I got 23 HP, but I already had a cam. A friend of mine put headers on his stock car and gained maybe 10 HP and barely any torque, very disappointing. I added heads and got about 30 HP but I already had the cam and headers, I have to believe that heads on a stock car would be minimal.
It goes like this, heads require a cam to help get more air in and headers to help get more air out. Headers don't do a lot of good without having more air in, so you really need a cam at the least, maybe heads. For the best bang for your buck money increase, do the cam, then headers, finally heads. Of course some of this may require duplicate labor so it would be ideal to do it all at once. If you've only got around $500 you can't go wrong with the hot cam kit, it certainly was the best bang for the buck on my car at approximately 44 HP over stock, a better gain than any of my other individual mods have given me.
I actually stumbled into the proper progression of modifications quite by accident, it was simply done as money permitted. As it was though it was really the best order. Click here if you want to see my progression of horsepower increases http://www.wku.edu/~nathan.plemons/h..._corvette.html
Click here if in general you want to see my thoughts on LT1 performance http://www.wku.edu/~nathan.plemons/h...rformance.html
It put down 298rwhp/310rwtq. This was with the stock exhaust manifolds with a Corsa cat-back. That's about 30+hp from just a set of heads. I think the car ran 12.6 before I put the hot cam and headers on it.
This is like a "free" mod if the engine's down anyway. I use them on my current package, won't be able to on the new bottom end due to clearance and C/R issues. These will give you nearly a half point of increased C/R. They are .029" compressed, your stock ones are .049".
Installing a hot cam on a stock LT1, you will feel the hp gain, no doult about that. But to get much more as everyone is talking about here is to install a ported heads as well. But if you are under a budget. Cam first than if your want more later, add a ported heads. A typical head/cam combo with good tune can get you 350-375rwhp.
Bruce
Hotcam kit first makes a lot of sense since it costs about 500 it fits your budgetary requirement. LTs and porting are more than 500 bucks, and the hotcam kit will provide a solid foundation for future mods.
with Nathan.LT1:
Port Stock Heads
LT4 "HotCam" Kit
LongTube Headers
Gears (3.73 for A4, 4.10 for M6)
Converter/Clutch (3000rpm Converter/Aftermarket Clutch)
Those mods, should make for a VERY fun LT1
