New Cam
Old Aug 7, 2005 | 10:04 PM
Kehrer923's Avatar
Kehrer923
Default New Cam
I am finally getting the car back from paint and I am rebuilding my 383. Heres the cam I selected and specs what do you think?
COMP CAMS
Solid Roller
248 248 Duration @ .050
.609 .609 Lift + 1.6 rr= .647 total lift
114 lobe center
I also have my old zz-x for sale if anyone wants it.
Old Aug 7, 2005 | 10:20 PM
Pete K's Avatar
Pete K
How much compression are you going to have?
Old Aug 7, 2005 | 10:45 PM
Kehrer923's Avatar
Kehrer923
Old Aug 7, 2005 | 10:50 PM
Pete K's Avatar
Pete K
Sounds like you picked the right cam.
Old Aug 7, 2005 | 11:33 PM
Bruce's Avatar
Bruce
430-450rwhp range. Nice combo
Old Aug 7, 2005 | 11:43 PM
Kehrer923's Avatar
Kehrer923
TPIS said their car with this combo made 568 fwhp, curious to see what it will do
Old Aug 7, 2005 | 11:57 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
OMG that's a lot of lift!!! That car is going to PULL hard!!!
Old Aug 7, 2005 | 11:59 PM
Kehrer923's Avatar
Kehrer923
Yea, I had the zz-x before with .558( 1.6's .595), and it was awesome. It would pull to 7 k and i would have to shift, but it was like it would jus keep going. and this cam is pretty similar and solid
Old Aug 8, 2005 | 12:07 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
WHat type of heads/intake are going with it?
Old Aug 8, 2005 | 12:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
What are the flow #'s on the heads?
Old Aug 8, 2005 | 12:45 AM
Kehrer923's Avatar
Kehrer923
just finished the valve job on the heads. I am going to run AFR 190cc competition port heads, and ported lt-1 intake, 54 mm Az Speed and marine billet TB.
Old Aug 8, 2005 | 02:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
There had to be more to TPIS's combo to make those kind of numbers. That sounds a little high to me.
Good luck on your buildup
Are your heads box stock, ported? Rearend gearing? Not enough info IMO. Your'e going to need an awesome tuner to make a short runner work with that much cam timing.
Old Aug 8, 2005 | 01:22 PM
Kehrer923's Avatar
Kehrer923
AFR CNC comp Port
3.73 gears
To New Cam
