Best LT4 Bolt ons?
Old Aug 8, 2005 | 11:45 AM
jedrake72's Avatar
jedrake72
Default Best LT4 Bolt ons?
What are the best bolt on power adders for the lt4 6m? I have heard that it does not respond well to tuning.
Old Aug 8, 2005 | 11:52 AM
CAJUN C4's Avatar
CAJUN C4
Tha stock LT4 OBD11 is pretty hot as stock.I do know the GM Hot Cam really wakes it up and let's it really breathe along with Long Tube headers.and maybe the Corsa exhaust.. 40-50 HP + gain.
Old Aug 8, 2005 | 11:58 AM
redvette6spd's Avatar
redvette6spd
Some Lt headers a LT4 Hot Cam adjustable fuel regulator a cat back and a open air box and a good tune put me at about 407 at the crank
Old Aug 8, 2005 | 12:08 PM
No Go's Avatar
No Go
LT4's are very receptive to modifications...see my home page.
Old Aug 8, 2005 | 12:23 PM
STL94LT1's Avatar
STL94LT1
IMHO, 4.10 gears are the best LT4 mod.
Old Aug 8, 2005 | 12:34 PM
bogus's Avatar
bogus
Well... in CA, he can't do the LTs and the Hotcam is questionable. It has a tendency to throw misfire codes, so that would be bad.
I agree with STL94LT1, change gears. That engine is pretty hot from the factory... add a cat back (Corsa is a good choice), high-flow cats never hurt and an open lid air box or some form of intake.
The LT4 is very receptive to upgrades, but they are not "bolt on".
Another trick is to install an Impala SS head gasket. It's thinner.
Old Aug 8, 2005 | 12:36 PM
LT4POWR's Avatar
LT4POWR
- K&N filter with open air lid
- Rear end gears in the 3.90 – 4.10 range.
- Get the stock throttle body ported/polished to 52mm. Find/get a air foil port matched with it. Don’t waste your time/money dealing with the Holly or BBK units.
- A good catback exhaust
- Longtube headers
- Computer reprogrammed for the above mods
- Dyno it, just to make sure the air/fuel ratio is correct
- Hurst shifter
- NGK TR55 spark plugs, depending on age/condition good plug wires
Old Aug 8, 2005 | 01:15 PM
jedrake72's Avatar
jedrake72
Good point earlier, I live in CA so headers and most likely cam are out. Stupid CA smog...
Old Aug 8, 2005 | 01:24 PM
Perfusion's Avatar
Perfusion
I live in San Jose...you should come out to a meet sometime!
Old Aug 8, 2005 | 02:10 PM
VenkmanP's Avatar
VenkmanP
There are tons of people running hotcams running in CA with no problems. Just needs a good tune.
Old Aug 8, 2005 | 02:59 PM
LT4POWR's Avatar
LT4POWR
Since when did a cam become a bolt-on
Old Aug 8, 2005 | 03:05 PM
CAJUN C4's Avatar
CAJUN C4
Well,It's not exactly a "Bolt On" .Takes many, many removed bolts to do it.
To Best LT4 Bolt ons?
