Removing screens on MAF
I agree it won't make too much noticeable difference, but if it increases air, it increases the potential for power if it's tuned
This is actualy a myth. The air filter is what keeps the debree out and at a much smaller particle level then the holes in the MAF screen. The only reason the screen is there is to straighten the airflowout so it flows across the sensor better.
Stock Mass Air Flow sensor = 529cfm
Screens removed only = 711cfm
Screens and cooling fins removed = 750cfm
Ultimately, removing the screens and internal cooling fins from your MAF will provide less restriction to the incoming airflow.
The only benefit to doing this modification is that as you improve the engine's ability to take in air (ie. 58mm throttle body, large port/ported base, large-tube runners, ported plenum, SuperRam, MiniRam, etc...), there will be less restriction from the MAF. Of course, once the engine becomes capable of pulling more than 750cfm, then the MAF will become a bottleneck.
. This allows the sensor to provide a slightly more accurate reading. But the difference is REALLY REALLY small.
