Coolant Fans
Old Aug 13, 2005 | 07:56 PM
VT Solo2's Avatar
VT Solo2
Default Coolant Fans
Hi everyone, I'm wanting to wire up a switch to manually control the fans in my '96. Has anyone done this? I was thinking about just wiring a switch to ground the dark blue wire in the secondary fan relay. As far as I can tell, this should turn on the secondary fan. I also saw in the schematic in the shop manual that it will also activate the third relay, which has some control over the primary fan also. I haven't been able to figure out why GM used 3 relays to control 2 fans. Can anyone explain how this all works together and when the fans come on? So very confused right now. Thank you...
Old Aug 15, 2005 | 05:49 PM
VT Solo2's Avatar
VT Solo2
No one?
Old Aug 15, 2005 | 07:35 PM
Slalom4me's Avatar
Slalom4me
There are a couple of entries in the C4 Tech Tips section.
The topic has come up fairly often, so a search of the archives
should bring up quite a lot of info.
Old Aug 15, 2005 | 08:45 PM
the blur's Avatar
the blur
don't mess with it. they were very cleaver in 96. both fans either run in low speed or high speed. very cleaver design. they series the fans to split the voltage, 6v on each fan = low speed.
12 v on each fan = high speed. therefore 3 relays.
I was very impressed when I saw the design.
Old Aug 15, 2005 | 09:49 PM
VT Solo2's Avatar
VT Solo2
Yeah, that's the conclusion my roommate and I came up when we tried to figure out the schematic and what GM was trying to do. Oh well. Well, thank you for your help, I do appreciate it!
Old Aug 15, 2005 | 10:20 PM
Atok's Avatar
Atok
You would be better off to get the PCM reprogrammed to turn the fans on when you want them on.
Old Aug 15, 2005 | 10:21 PM
VT Solo2's Avatar
VT Solo2
I think you can do that with a Hypertech too, right? I was just trying to do an inexpensive mod, so I think it can wait...
Old Aug 16, 2005 | 07:56 AM
Atok's Avatar
Atok
Yeah, and I think TunerCat will soon support the '96 PCM, if they don't already. TunerCat would be cheaper than a HyperTech and you will be able to change whatever you want. Ask about it in the Scan & Tune forum.
To Coolant Fans
