Datamaster Help Please
Old Aug 15, 2005 | 07:44 PM
Muffin's Avatar
Muffin
Default Datamaster Help Please
I think I am the Typhoid Mary of scan programs. I have gone thru WinALDL,Freescan, both Moates versions and finally got TunerPro RT to run but couldn't figure out what the 72 pages of numbers ment.
Bought Datamaster/with cable,USB version, from AKM Cables and still can't get the dang thing to work. I have an 85 with a 7165 ECM. Running ARAP bin with vey few changes. Datamaster version is 32. Install version Beta. When I do the connection the laptop, select a Com port and run a test I get Error 1. That tells me the PC is seeing the USB adapter but the adapter is not talking to the ECM. During an earlier attempt I got a message which read"No PCM Sync", whatever that means. Had the key on and on several tries had the car running. Looked at the install and it is recognized as applicable to the 86-89 MAF Y car with AT.
Can any of you smart guys give me a clue.
Old Aug 16, 2005 | 02:06 AM
Morley's Avatar
Morley
"No PCM Sync" means it wasn't able to establish a link to the ECM.
What problems did you have with Craig Moates' software? You tried ECM 851 of his right? What cable were you using?
Do you have a 10k ohm resistor across pins A & B of the ALDL? Gotta have that one.
Old Aug 16, 2005 | 08:27 AM
Muffin's Avatar
Muffin
I tried both 851 and 852. I have used three cables. One home made, one from Custom efis and one from Moates. The first two had a 10k resistor. I assume Moates did also since it did work with TunerPro RT.
I guessed that was the meaning of No PCM sync. Any clue as to why? I really want to use Datamaster.
Old Aug 16, 2005 | 10:21 AM
jerrys 1989's Avatar
jerrys 1989
what year vett do you have ? im trying to hook up my1989 and cant seem to get it to work i made a cord not sure if it right or not how did you make your ? can you tune with the programs you have or jest see what the ecm is doing ? any input
thanks
Old Aug 16, 2005 | 10:39 AM
Muffin's Avatar
Muffin
Vette is an 85 BUT with an 89 ECM and chip. Have four cables, one homemade and three store bought. I can get the TunerProRT to log but would rather use Datamaster.
Old Aug 16, 2005 | 10:47 AM
jerrys 1989
were did you get the Datamaster ?
Old Aug 16, 2005 | 12:56 PM
mk842766's Avatar
mk842766
Same problem...no joy yet. I'll be keeping a close eye on this one, as I don't want to use up the free scans I have with Datamaster......
Old Aug 16, 2005 | 01:56 PM
SBNova's Avatar
SBNova
Jerrys 89- you cant flash a TPI style ECM through the ALDL port- so no, none of those programs tune just datalog. Most *can* make changes to a bin file, but require chips and a chip burner to do so.
Muffin- who did the 165 swap? Are you sure the data wire to the ALDL is correct? Have you tried looking up the ALDL wire on a schematic and hooking up your laptop to your ECM directly?
Old Aug 16, 2005 | 03:30 PM
Muffin's Avatar
Muffin
jerry, got it from AKM Cables.
Nova, I did the swap with a lot of PM help from Bluevette85. All the TunerPro RT scans I have done were done after the swap so I think it is wired correctly.
Old Aug 27, 2005 | 01:00 PM
zr1-2go's Avatar
zr1-2go
You might try some of the combinations of advanced settings under the options menu like handshake when you try to record data.
That worked for me.
Old Aug 27, 2005 | 04:16 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I am haveing problems too, and it usually comes downto port settings in hardware device, ports properties.
I know there are certain settings, and last time I used it I had to change the settings etc.
To Datamaster Help Please
