700R4 and speedo correction
Old Aug 16, 2005 | 05:50 PM
91superram's Avatar
91superram
Default 700R4 and speedo correction
What is the correction gears for the drive gear and the driven gear on a 91 auto. I know that on a 6 speed its a grey 15 teeth gear and a purple 42 teeth gear.Is it the same for a auto tranny.
Old Aug 16, 2005 | 06:45 PM
CFI-EFI's Avatar
CFI-EFI
What needs correction??? Why?
Is that so? First, the 42 tooth driven gear is green. The purple gear is a 43 tooth driven gear. The correct speedo gears depend on several items, besides the year and the trans. The tire size and gear ratio are equally important.
RACE ON!!!
Old Aug 16, 2005 | 07:24 PM
Brimis's Avatar
Brimis
Don't I know! Learned something new about speedo sensors everyday since last week!
Old Aug 16, 2005 | 07:47 PM
91superram's Avatar
91superram
It's a 91 with a 700R4 tranny
upgraded to 3:54 gears
Tire's 275/40/17
Stock drive gear is red 17 tooth
Stock driven gear is white 36 tooth
My question is to correct my MPH reading do I have to go with a gray 15 tooth drive gear and a purple 43 tooth driven gear can someone confirm this for me, and is the part# for a gray drive gear for a 700R4 (8642620)
Old Aug 16, 2005 | 08:46 PM
CFI-EFI's Avatar
CFI-EFI
I see you have changed from 2.59 gears.
That is correct. The driven gear is 25513050. You will also need a 10456092 VSS.
RACE ON!!!
Old Aug 16, 2005 | 09:08 PM
91superram's Avatar
91superram
CFI-EFI
To 700R4 and speedo correction
