I know this has been discussed before, but I couldn't find anything using the search function. Does anyone know of any business that specializes in injector cleaning, and flow testing, that you have personally used. My car is a 1991, L98, automatic. I have the plenum, runners, and intake manifold out for powder coating so I wanted to get the injectors serviced while I have everything apart. Also when I pulled the intake manifold I noticed there isn't gaskets on each end of the intake manifold which apparently is normal. I have heard that these are susceptable to leaking, what does everyone in the forum do during reassembly as far as sealant?? Any comments or suggestions would be appreciated. THANKS!!
www.cruzinperformance.com He does great work for a reasonable price. I had mine done a few years ago and I know alot of other members here have used his service.
For the intake manifold, use "The Right Stuff" by Permatex on the front and rear. I followed another forum members suggestion and "dimpled" the front and rear block walls with a center punch to give the sealant a better surface to grip. Hasn't leaked a drop since.
