Prolonged cranking to start
Old Aug 17, 2005 | 07:56 PM
Hunter16's Avatar
Hunter16
Default Prolonged cranking to start
Just bought a 1989 with 64k on it. Overall car is great but have one issue that I will need to have fixed. I did have a mechanic look over vehicle before i bought it. He told me he would have to do a much more indepth check of the car to diagnose the exact problem. I stil bought the car because both he and I felt the price was well worth the vehicle. Anyways I was hoping to get an idea of what i can expect to hear the problem might be, before i take it into the shop. When turning the ignition to start, the car cranks for about 2 seconds before it finally starts. It always starts, yet it always has an extended cranking period before it starts, whether the car is hot or cold. I am brand new to CF and brand new to owning a corvette, so if you are kind of enough to reply, please try and use nice and simple terms. Thanks much
Old Aug 17, 2005 | 08:13 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
2sec or 20sec?You need to check your fuel pressure and do a leak down test on it.You are either leaking back to the tank(fuel pump) or leaking into the intake(pressure regulator) is my guess.It could be a bad fuel pump or clogged filter too.Filter should be changed on a newly recieved car as general maintenance.All of these things can be done by you saving a lot of money.A Helms manual would help too.
Old Aug 17, 2005 | 08:21 PM
Hunter16's Avatar
Hunter16
Thanks Red, the cranking lasts for no more than 2 seconds, but always happens. I did find on CF that a brand new C4 owner should get the book "101 projects for your..." so i ordered it 2 days ago. Again, I am a total newb to this, the Helms? gonna check google for it, hopefully i can figure that out.
thanks again
Old Aug 17, 2005 | 08:40 PM
Redeasysport
Helms is the factory service manual about $100 at Helms cheaper if you can get one on eBay.
2 sec is not extended cranking mine was taking 10-15sec before I fixed it now it is about 2 sec at the most. Try turning the key on and waiting for 4 sec before starting to allow the fuel rail to pressurize.Turning it straight to start can take a sec for the fuel to flow. If you leave the hood up when you turn the key on you may hear the fuel rushing into the rails.
To Prolonged cranking to start
