Fan Switch Trouble ???
Old Aug 17, 2005 | 08:12 PM
corveteer's Avatar
corveteer
Default Fan Switch Trouble ???
87 Z52 purchased ecklers fan switch. it is supposed to turn fans on at 200 and off at 185. car has 180 thermostat. it turns on fans at 200 fine --no problem. then you rev up to 1200 rpm to cool it down and temperature goes to 180 or even 179 but fans will not turn off. it is absolutely the fan switch because you can walk over and pull wire off of the fan switch and fan stops immediately.
did you have this problem? any and all suggestion appreciated
thanks for your help
stark@cameron.net
Old Aug 17, 2005 | 11:29 PM
1986vert's Avatar
1986vert
I just got one from them today so I can tell you how it reacts on my 86 but I don't know if I will get below 180 in the AZ heat for awhile. Did you set it up to control both fans ? How much fluid did you loose when you installed it ??
Old Aug 18, 2005 | 12:32 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Gotta be the switch. Your 180 t-stat probably isn't fully open at 180, and if that switch isn't accurate, it'll hardly ever shut off.
If you park and let the motor cool with key on, when does the fan cut off?
I'd recommend a fan switch override if you're looking for more power/consistency at the track.
Old Aug 18, 2005 | 03:03 PM
corveteer's Avatar
corveteer
yes green and white from both fans and mid am aux fan.
it is better than the original
did not lose much antifreeze ---have replacement ready and pop it in there
To Fan Switch Trouble ???
