automatic door locking on 95
Old Aug 19, 2005 | 02:14 PM
bobbiedb's Avatar
bobbiedb
Default automatic door locking on 95
Just got a 95 LT1 with PASS keyless entry system alarm system. This is my first Chevrolet product and was wondering about the door lock features.
If i don't have the PASS transmitter in range of the car should the doors unlock automatically when i turn the key off?
Also should the doors lock automatically when i start the car, put it in drive and drive off?
Second subject: Will it run better if i put ford emblems on the side and hood?
Old Aug 19, 2005 | 02:18 PM
VenkmanP's Avatar
VenkmanP
Took me a minute to figure out what PASS was. It's called "passive keyless entry."
No.
No.
If you need an owner's manual you can get one here:
http://www.helminc.com
Welcome to the club.
Old Aug 19, 2005 | 02:25 PM
bobbiedb's Avatar
bobbiedb
thanks.
I have an owners manual and a Helms 2 volume service manual. neither show it will do what i hoped it would do.
I was just wishfully thinking and have been spoiled by my fords.
I asked because i installed remote start/window rollup/2 stage door unlock/door unlock/ hatchback release before i checked out what the factory functions were and they messed up the remote start install. i am getting all kind of funny actions from the remote start. For instance when it remote starts the doors will unlock every 2 to 3 minutes.
I wanted confirmation of what was stock before i returned to the installer.
thanks.
Old Aug 19, 2005 | 03:03 PM
dndrsn's Avatar
dndrsn
Can't help you with the PKE question but if you put Ford emblems on a Corvette it will cause the fiberglass to rust.
Old Aug 19, 2005 | 03:11 PM
bobbiedb's Avatar
bobbiedb
That is a good one! Fiberglass rusting. I worried that it might be Found on the Road Dead or have to be Fixed Or Repaired Daily.
Old Aug 19, 2005 | 03:24 PM
bobbiedb's Avatar
bobbiedb
Actually PASS is "Personalized Automotive Security System (PASS-KEY)"
Old Aug 19, 2005 | 03:58 PM
dndrsn's Avatar
dndrsn
"Passive" because you don't have to push buttons to lock/unlock the door.
Old Aug 19, 2005 | 04:19 PM
VenkmanP's Avatar
VenkmanP
Pass-key is what was originally called VATS, which has to do with the ignition key. Has nothing to do with the keyless entry.
Old Aug 19, 2005 | 07:34 PM
bobbiedb's Avatar
bobbiedb
Don't tell me, tell Helms Inc. They are the ones using the wrong terminology in their service manuals.
I guess GM should correct their owners manuals also. Page 2-14 says that PASS-Key is a "passive theft deterent system".
Old Aug 19, 2005 | 08:47 PM
dndrsn's Avatar
dndrsn
Exactly. Passive theft deterent system is the ignition key with the resistor pellet in it.
PKE "Passive Keyless Entry" is the fob.
Stick a fork in me.
Old Aug 20, 2005 | 10:10 PM
VenkmanP's Avatar
VenkmanP
No correction needed, as you are reading in the manual about the ignition key security system, not the keyless entry. As I said.
To automatic door locking on 95
