Does Anyone Know........?
Old Aug 20, 2005 | 04:46 AM
Illvtvette's Avatar
Illvtvette
Default Does Anyone Know........?
If the oil pan on a 96 coupe LT1 will come off with the engine in the car? Is there enough room to jack the engine a little if the mounts are unbolted?
Old Aug 20, 2005 | 06:22 AM
Cherry6speed's Avatar
Cherry6speed
Yes, it will and the motor does not need to be jacked up. You will need plenty of room underneath to work with though.
Old Aug 20, 2005 | 06:30 AM
Illvtvette's Avatar
Illvtvette
Thanks RRV !!!
Old Aug 20, 2005 | 07:34 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Remove the oil level sensor from the pan before removing so you don't break it off.
Old Aug 20, 2005 | 12:59 PM
Illvtvette's Avatar
Illvtvette
Will Do!
Old Aug 20, 2005 | 01:02 PM
STL94LT1's Avatar
STL94LT1
Yeah, I learned that the hard way.
To Does Anyone Know........?
