High amp alternators - what do you have?
Based on the forum search, it looks like I have the following options:
1) Upgrade to the CS144 from a 1996 Corvette and lose the bottom support brace (otherwise a plug and play).
2) High Output Unit from www.alternatorparts.com. (Unsure of how plug and play the install is).
3) PowerMaster unit (same as #2)
4) Corvette Clinic upgraded GM Delco unit (pricy, but supposed to be a direct fit).
5) Have a local shop rebuild mine.
Car is reading approx 13.5 on the volt meter during cruise after its warmed up and with more driving, 13.3 and 13.4 is not uncommon.
I'd like to hear from any folks who have upgraded their alternators. I'm not super crazy about losing that lower support with the CS144, but enough people have done it without problems for me to consider doing it on my car. Any other experiences with the other options would be greatly appreciated. Please include any installation gotchas that you encountered with the switch.
Thanks,
Ron
I'm looking for someone to make one for use with my TPiS headers, I'm almost sure the original wont work.
Ron
Ron
Bulletin No.: 43-64-07A
Date: January, 1997
INFORMATION
Subject:
Low Voltage Reading or Dim Lights at Idle
Models:
1990-97 Passenger Cars and Trucks
This bulletin is being revised to add the 1996-97 model years and to update text. Please discard Corporate Bulletin Number 43-64-07 (Section 6 - Engine).
Any vehicle may have a low voltage reading (if equipped with gauges) or lights that dim, when electrical loads are heavy at idle, or under very slow driving conditions. This condition may be worse with owner added electrical accessories, or with a discharged battery. THIS CONDITION IS A NORMAL OPERATING CHARACTERISTIC OF THE VEHICLE, AND NO REPAIRS SHOULD BE ATTEMPTED UNLESS A PROVEN FAULT HAS BEEN FOUND.
At idle, vehicle electrical loads may exceed the low speed output of the generator, but the battery can make up for this shortfall from its reserve capacity for short periods. During normal driving conditions, the generator is designed to do two things: supply the necessary vehicle loads, and recharge the battery. Long periods of battery discharge due to high accessory loads at idle will cause the electrical system voltage to drop as the battery continues to deliver the electrical power. Increased generator temperatures from extended idling can also contribute to lower electrical system voltage. As temperatures rise, the voltage setpoint is reduced to avoid battery overcharge, and the generator's output capability is reduced due to increased electrical resistance.
Depending on the vehicle application, normal generator output at idle can be as low as 35% of the full rated output (see Figure 1). With enough electrical loads, it is easy to exceed the low speed generator output at idle. This is a NORMAL condition that the battery can compensate for during short periods. Items that affect the vehicle system voltage at idle are driving conditions, the number of electrical loads being used, add-on accessories, and extended idle times. Normal driving conditions will recharge the battery and restore the charging system to its normal state.
Some typical electrical loads are:
Load Amps
Rear window defogger 25
Headlamps (low) 15
Headlamps (high) 20
High blower 20
Windshield wipers 6
Ignition 6
Brake lights 5
Dimming lights at idle may be considered normal for two reasons. First, a vehicle with a low state-of-charge battery or under a discharge condition will have a normal low voltage condition. As vehicle speed changes, so will the output of the generator. As a vehicle slows, the output of the generator may not be sufficient to supply all demanded loads, so the vehicle system voltage will drop, and the lights will dim. Secondly, as high current loads (blower, rear defogger, headlamps, cooling fan, power seats or windows) are operated, the regulator can delay the rise in output. This effect, usually at lower engine speeds, can take up to ten seconds to ramp up the generator output. This is done to avoid loading the engine severely, so that engine speed variations caused by the increase in generator output are not noticeable to the driver.
Component Functional Tests
Make sure all battery and ground connections throughout the engine compartment are secure and tightened. The battery and generator performance can be checked as follows:
Battery
1. Turn the ignition switch and all accessories "OFF."
2. The battery should have a "green eye" and the terminal voltage should be greater than 12.0 volts.
3. If not, the battery should be charged and tested following the instructions in Section 6D1 of the appropriate Service Manual before testing the generator.
Generator
The regulator lamp circuit provides the best diagnostic indicator for generator faults. Confirm that the lamp is operating properly, and isolate the unit with the Universal CS Generator Tester (J 41450-B).
1. WITH ALL ACCESSORIES OFF, run engine above 2500 RPM.
2. Diagnostic lamp should remain off. Voltage at the battery terminals should be between 14.0 and 16.0 volts when cold, and between 13.0 and 15.0 volts with engine at normal operating temperature.
3. Install a carbon pile tester (VAT-40 or equivalent equipment) across the battery and an inductive ammeter on the generator output wire(s).
4. Run the engine above 2500 RPM and load the charging system until peak output is reached.
5. If the peak measured current is within 70% of its rated output and the diagnostic lamp remains off, the generator is good.
If the generator does not perform to the above tests, refer to Section 6D3 of the appropriate Service Manual.
FAST also notes possible driveability issues when voltages dip below ~13.2 and it's been talked about on turbobuick.com several times as well. I'm not experiencing this issue, but could be on the cusp of this if I was to ignore the problem.
What really appears to get the car struggling is the rear defog (which usually gets turned on when its dark out so the headlights are on). I can see voltages in the 12.5 range which never used to happen before. The current alt is yet another CS-130 Delco installed just over a year ago. Battery was also installed at the same time. Upon load testing both devices (battery and alt) - neither one was particularly good and both showed signs of near-term failure.
In addition, the longer that the car is driven, the lower the voltages tend do go. When first started, voltmeter is reading 14.0-14.2 and 30 mins later, we're at 13.4-13.5 with no accessories running besides the fans.
After talking with both Powermaster and Alternatorparts.com, looks like the CS-144 installation via tech tip and a new battery will put the charging system back into tip-top shape for me.
Ron
Ron
I installed one recently on my stock alternator (105 amp?) and now I always remain above 13.5 volts at idle, with all the loads (stereo, amps, aux fan, a/c blower and lights)
Can't say for sure what this will do for the longevity of the alternator, but a local shop rebuilds them (replaces bridge, regulator, and bearings) for less than $50, and the pulley only set me back $20, so it will be a while before I spend the $300 that one of the "Extrerme Duty" version's cost
Gary
Ron
