Voltage to maf
Old Aug 21, 2005 | 06:53 PM
MR.KIDD's Avatar
MR.KIDD
Default Voltage to maf
How do you convert voltage to maf?
I have a innovative wb and can monitor maf voltage but need to translate voltage to airflow.
Old Aug 21, 2005 | 08:09 PM
Bluevette85's Avatar
Bluevette85
There is no direct formula. There are 5 tables in your bin that have MAF volts vs airflow. This is the airflow number that shows on a scan tool. You can adjust the airflow number up to add fuel and lower it to decrease fuel.
I also have the Innovate WB and have it log RPM's. I can also output the AFR into Tunerpro.
Old Aug 21, 2005 | 08:42 PM
MR.KIDD's Avatar
MR.KIDD
I was trying to put rpm & airflow &fuel ratio together.Thanks for the response.
Old Aug 26, 2005 | 03:28 PM
gnjones231's Avatar
gnjones231
2nd Gear
Yes, there is a formula to convert volts to airflow. All hot wire meters follow the formula ....
airflow = a + b * (volts) ^ 1/c
If you can post the volts vs airflow from the tables in your bin, I can provide you with the appropiate formula.
HTH
Dave
To Voltage to maf
