Got the car back today and ..
Could the TV cable not be hooked up right at the tranny? or worse, could the torque converter not be installed correctly?
If that all checks out, readjust it. Running it with an unhooked or broken cable will ruin the trans.
I had wondered about the weird screw the guys used for the tensioner mounting bracket, looked like a wood screw .. anyway the bracket snapped and the belt went. In a few sec. temp went to 240 and I shut it down, luckily at my driveway.
It's kind of a custom setup after removing smog pump and AC. Anyway, time for some re/engineering there. Anyone have the original mounting brackets for L98. Maybe time to back go to GM engineering.
The new 355 TPI is ****. will be fun to get back on the dyno, may not have a lot HP. but lots of torque.
I guess I just have to resign myself to the fact I have to do this work myself. I had the governor perfectly calibrated, Raptor must have replaced the valve body .. I'll call them later to see. I have yet to check how the cable is connected to trans.
TV cable seems adjusted alright, tight at wot. I had the Governor recalibration spring combinations all down, and now I can't remember, it's a Reagan thing
