LT1 Pistons?
Old Aug 23, 2005 | 08:29 AM
cjg454ss's Avatar
cjg454ss
Default LT1 Pistons?
What kind of pistons are in a 94 corvette. are they hyper, or cast or what. also will they be able to take a vortech supercharger at 6 lbs of boost.
Old Aug 23, 2005 | 03:49 PM
Scott94C4's Avatar
Scott94C4
Hypereutetic (sp?). Read the multiple posts about this. Trying using the search....
Old Aug 23, 2005 | 04:03 PM
cjg454ss's Avatar
cjg454ss
i did a search, nothing really came up that said what they were stock.
Old Aug 23, 2005 | 07:18 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Hypertech pistons and powder rods ,not that strong of a combo even though some will disagree.
I have run a 125 shot of nitrous for about 2 years on them.
I think 4 lbs of boost would be ok ,but you would have to figure out the presure you are putting on the pistons and see if 125 shot would equal a 6 lb of boost.
You might have a problem with the trans and rearend if you put to much power to it.
Old Aug 23, 2005 | 08:13 PM
Baldturbofreak's Avatar
Baldturbofreak
They are indeed a strong piston, produced by MAhle. I ran 9 psi for a while on them but be warned, your tuning must be on the safe side or spot on. One mistake and those ringlands will be gone.
Old Aug 23, 2005 | 10:10 PM
cjg454ss's Avatar
cjg454ss
how do i make it on the safe side? pull timing? richen it up? i want to run the stock pulley which is 6-7 lbs from vortech
Old Aug 23, 2005 | 10:38 PM
Baldturbofreak
Buy yourself a wideband and make sure it stays less than 12-1 a/f under boost. 11.5 is even better.
Old Aug 26, 2005 | 09:29 AM
ztrips's Avatar
ztrips
I'm with BTF.. Stock bottom end can handle a ton of power, if you tune it right. A few pings at 9lbs and you'll be picking up pieces. Back the timing, run alky injection, keep the AFR under 12.5 to be safe. Make sure you have a fuel pressure guage, a wide band would be wise as well.
To LT1 Pistons?
