EGR Blockoff plates
Old Aug 24, 2005 | 03:52 PM
vader86's Avatar
vader86
Default EGR Blockoff plates
Is it necessary to remove the runners/rail on the pass. side to get access to those bolts on the EGR tube? It looks like you could just take off the distributor to get the top bolt, but the one underneath looks like it could be a bitch to get at.
Old Aug 24, 2005 | 04:23 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Eesh, you might be able to. SR or TPI runners?
I think you might need to pull that runner if its SR, not sure about TPI.
Ok, w/o the EGR pipe there (I have block-off plates) I can access both bolts in my block-off plate. This is with an allen head bolt too. All I need off is the vc's and you have at it. I think if I remember correctly the egr pipe in the stock plate that goes there, makes it funky, and thus might need to pull a runner.
Anybody else know better?
Old Aug 24, 2005 | 04:25 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Just one thought...SMOG ****'S.
Good Luck.
Old Aug 25, 2005 | 02:30 PM
vader86's Avatar
vader86
ttt
Old Aug 25, 2005 | 02:38 PM
JackDidley's Avatar
JackDidley
Seems like I used a 1/4" drive torx and got to mine without taking out the distributor. If you take the tube out of the header it should wiggle out of the way so you can get at the bottom bolt.
Old Aug 25, 2005 | 04:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I just had my intake off and used a narrow body Torx on a 3/8" extension to get to all 4 EGR tube bolts (my '88 has bolts to a flange on the exhaust header).
BTW, if you run a 160deg T-stat & fan switch your ECM will not call for EGR; it only does so during cruize when coolant temp is over 175deg F.
Old Aug 25, 2005 | 08:21 PM
vader86's Avatar
vader86
The car will definitely still get to 175F, especially when its 110F heat index outside, so I will run into Code 32 issues. I already have the aux fan coming on early, and the main fan comes on at 195. I may just try your diode trick, or have a chip made to take out EGR function entirely.
I'm about to install headers that have already had the EGR port plug welded, so I'm going to have to delete EGR, pointless to try to cut and weld through the Jethot ceramic coating.
I just dont want to have to make this a bigger job than I need it to be.
Old Aug 25, 2005 | 08:27 PM
JackDidley's Avatar
JackDidley
You can just remove the tube and block the hole on the intake end. Leave the rest of the EGR in place and the ecm will think it still works. No code.
Old Aug 25, 2005 | 10:29 PM
65Z01's Avatar
65Z01
On an '86 the ECM will throw a code 32 if it calls for EGR and doesn't see the EGR Temp switch grounded, indicating that eshaust gas is flowing into the intake.
To EGR Blockoff plates
